A new BIOS isnt going to pysically change anything that you have on the board - rather than ebay why not reflash to your previous BIOS? I presume it still posts BIOS.
Thanks - sounds like I shouldnt buy one of them. Before you lap check whether the CPU IHS surface is already even or not. A drop of water on CPU and then put a plate of glass on it. Check even spead or not. I lapped and it made not a jot of difference on the e6600 as it must have already been flat - looks nice though! if you want to try there is a guide on this site http://www.thetechrepository.com/
and a lot of other useful stuff such as MBM5 v 2
Nice link - I'll follow that if I plan on lapping the CPU. I was thinking more about the HS, but I will check to see if the IHS is flat on the CPU and consider lapping that also if it isn't.
I won't be doing this until week after next as I will be away from home next week, but I will post my results and let you know once it's done.
Thx for the replies.
P5W DH Deluxe Memory QVL
91.52 (KBytes)
2007/05/17 update
http://support.asus.com/download/dow...Language=en-us
Hi guys.
So I still have this problem that my mobo won't boot with a 8x multiplier. It can do 9x400 fine, but 8x400 or even 8x266 won't work. Mem timings are SPD Enabled etc too, I have tried anything but no fix.
As I'm still using 1707 bios, do you think flashing to 2004 might fix?
i dont think it will Gig4moller
well it didnt for me either
I haven't checked this thread for some time now but I am wondering have Asus fixed the shutdown problem with the motherboard yet?
One shuts down in windows but the motherboard just reboots instead of shutting down.
No such problem here..
whats up with my board or is my cpu i cant get orthios stable past 3.33ghz e6700 and get get my fsb past 370 or is it both the problem?
Hi all, my 1st post in this thread since following its conception. I have a early revision board and use corsair xms2 6404v1.2 D9s with a l624a and have always been able to post with manual memory settings upto 390fsb although unstable with orthos and only stable at 3.33ghz. Temps after the system had been on for a few hours browsing etc where between 36-41c, room temps about 20c and under load would never go above 52c not that impressive considering my w/c setup(as per sig).However today I managed to get hold of a l644g380 was wary of these chips as I had heard that they not the best of batches, but it appears I have got a better than average one , I can now boot into window 400fsb using 1.4875vcore and it is stable running games, encoding etc, however it craps out in orthos after 5hrs blend priority 9,sometimes with an error and sometimes just plain reboots? Temperatures now are incredibly low compared to my original chip, idling low 20s and under load 40c room temps where 22c so this is a definite improvement in 1 area and this is unlapped, unlike my last chip which was lapped! My question is how far would you raise the the other voltages safely? I have removed the heatsinks applied AS5 and have fitted 40mm akasa fans to the NB and SB, chipset temps never go other 39c. Ram has active cooling aswell.
It does 4 hours plus Orthos so unless you are seeking to post benchmarks on sites demanding 24 hours orthis its pretty stable and probably good enough for any game you can throw at it - I would be happy with that. If not up vcore to 1.5 and run again!. Itry bumping MCH to 1.65 first if not already done.
No GascogneThe board has not done that since near the beginning. Mine never did it! I have had this board since June 06 and I believe it to be the best so far for ease of use and great speed at any given clock when compared to other boards at the same clock. I now look forward to the X38 board coming down the pipe. I also currently use a P5NE-SLI that is a Great OC'r. But I will always remember the P5W DH as a truly great board!!
WZ
When is the funeral? :rolleyes: :ROTF:Quote:
Its probably a windows problem rather than the board - here is a link for all things windows reboot on shutdown problems. http://www.aumha.org/win5/a/shtdwnxp.php let us know if it is one of them! If that dont work it may be worth checking your PSU - I had an old machine that kept rebooting and it turned out to be a dying PSU problem.
Hello!
Anyone here who has 2 gfx adapters in this motherboard?
I've tryed with 2 Nvidia card, my main gfx card is xfx 8800gtx card and the secondary is nvidia 6200 card. I've even tried a pci card.
I dont want SLI, i just want 3 DVI outputs (2 monitors and one pj)
and it doesn't work? Have you configured the nvidia drivers correctly?
No... or... it dont show up in Windows. I've tryed to add the gfx adapter manually, but that didnt work.
i'm sure this has been asked, but I just can't figure it out!
I have an E6600 with Kingston HyperX PC2 9600 and an ENERMAX 500W. I have DD water cooling on the cpu, and just bought two thermalright hr-05 and one thermalright hr-09 mosfet cooler. Before I got the thermalright pieces, I was running a p5w dh rev. 1.02G BIOS 2004 at max 340fsb stable either 1:1 or 2:3. This is at very high voltages: 1.6v cpu, 2.3v ram, maxed out the rest.
(I don't know much about MEMtest or other windows ocing software.)
Well, yesterday out of laziness I tried to remove the stock cooling's push pins without removing the board - and ended up breaking one of the MOSFETS! :shocked:
I went to the market today and interestingly I found a P5W DH with a "1333 FSB effortless!" sticker on the box. I looked inside and found that it's 1.40G so I decided to try my luck with it.
Now, my question to all you 500+ fsb overclockers: What dividers and voltages can I use to go that far?!! Can it be done from the BIOS? :shrug:
please help! This thread is overwhelming - if someone can point me to a relevant post here I'd appreciate it.
Good joke - I presume that was a mistype and you meant 400 FSB because I think you will find hardly anyone (if anyone at all) has hit 500 on this board.
To get you started on the way to overclocking nirvana use this link to an overclocking guide and take it from there. http://forumz.tomshardware.com/hardw...ict197995.html
