Just had to post to say that I've got my new E8400 running at 4.05GHz on my DQ6 rev 1 with F12j bios...sweet!
Well time to post my results here :)
Hardware:
Mobo:Gigabyte 965P-DS3 revision 3.3
Processor:E8400 Stepping 6 Rev C0
Ram: 2x1Gb Corsair XMS2 PC6400 (DDR2-800) rated 4-4-4-12 @ 2.1v
PSU: OCZ 600w GameXstream
GPU: Geforce 8800 GTS 512mb (G92 core)
Cooling: Thermaltake Big Typhoon VX and extra fan on MCH
BIOS: F13Q beta
Results: (all voltages monitored with cpu-z 1.44.2 and temps with coretemp 0.98.1)
3.41Ghz,FSB 379,Mult 9x
4-4-4-12 @ 379 +0.3 ddr2 volts
BIOS volts 1.24375
Idle volts 1.200-1.216
Load volts 1.184
Idle temps: 37-39
Load temps: 56-56
Prime95 3h 30m stable
3.6Ghz,FSB 400,Mult 9x
5-5-5-18 @ 400 +0.4 ddr2 volts
MCH +0.1v
FSB +0.1v
BIOS volts 1.30625
Idle volts 1.264
Load volts 1.248
Idle temps: 35-39
Load temps: 59-59 max 61
3.8Ghz,FSB 422,Mult 9x
5-4-4-12 @ 422 +0.3 ddr2 volts
MCH +0.2v
FSB +0.1v
PCI-E +0.1v
BIOS volts 1.38500
Idle volts 1.344
Load volts 1.312-1.328
Idle temps: 40-40
Load temps: 65-65 max 66
Prime95 9h stable
Orthos blend test 6h stable
Note 1: Temps are surely off by about +10C since the air coming out from my big typhoon isn't nearly hot for 60c and this kind of OC would never produce such heat with so good cooling ;) Realtemp reports exactly 10c down,so I guess that's the real value
Hope this helps :)
Could anyone confirm 45nm CPUs are supported on the GA-965P-DS4 R1.0 with the latest bios F11 ?.
According to Gigbyte, it wont work but i saw people with E8x00 on their 965P-DS4 R1.0.
I dont mind to change the motherboard for a P35, but if the 8500 will work on my 965p, better :D.
is the 965p-ds4 any good with wolfdales?
There is a new bios update for p965 ds4 2.0, 12A, i dont know if i should upgrade from bios 11 before i put teh new e8400
unbelievable! my thread is almost 3 years now!
Hi guys,
This is latest BIOS for:
GA-965P-DQ6 - F13a
GA-965P-DS4 - F12b
GA-965P-DS3P - F7a
GA-965P-DS3 - F14d
GA-965P-S3 - F14a
Link to download in my sig.
