0.745 means your GTL is @ 0.62 [0.745/1.200], I think it should be 0.760 which will give 0.633, you can check this values with ET6
What? No, I am saying that my, CPU Reference, likes to be set at .63V, when, the FSB Term is set to 1.20V. That is my stable spot for my, CPU. Every CPU is different a little. Also I will add that as you are moving up in speed and FSB Term, the spot changes a little at a time but, again every CPU is different so take that with a grain of salt.
truehighroller: I tried ur settings, hoping I missed a setting relating to my RAM (clock skews, DDR write training, MCH volt), and I still get errors (2errors@6min mark), thanks for posting ur settings though. I might be getting these errors bc my NB temp is getting too high...it feels very hot to the touch. I still havent modded the NB in any way, not even a fan.
Can some of the experienced guys chime in with the importance of adding cooling to the NB, and at what voltage u should add a fan...mine is at complete stock. How important is it too have air cooling the NB?
I use 1.40mch for my 24/7 at 500*9/1250 and when I had the stock heatsink on it would get pretty hot when priming even with a fan on it. I also noticed that since the first ram stick is so damn close to the nb heatsink it would get alot warmer than the second stick. I ended up getting an EK 5 waterblock for the NB which took out alot of heat and keeps it away from the ram which stay at even temps now. If I were you I would atleast pull the blue cover plate off the nb and put a fan on the heatsink and ram.
You indicate your nb is hot to the touch, you get two very good tips and, you haven't bothered to even try them out and you still want more? And the rudeness.... :shakes:
FWIW Hoss' tip is excellent. :up: How do I know? It's what I've done; pulled the top cover plate and have a 40mm sitting right on the nb, and my results are close to what these guys on water have.
Overclocking is all about being creative, and the little things actually make a hell of a difference. With your attitude, no one will help you; which is not bad because sometimes learning things the hard way has its own rewards. :rolleyes:
:up:
For those on strictly air trying to run with the big boys, you definitely need to use better thermal paste, be sure your mobo is not warped and that the mosfets are making good contact with the heatsink, peel of the cover plate on the NB (may void warranty, shouldn't :down: ), then put a fan on it, preferably one that blows towards the mosfets too - if your cpu fan isn't the type that blows cool air to surrounding components.
Here is a quick run I did just did to show that 1.7v on the nb is possible with active cooling on the nb.
1.7v NB (ambient: 24c) - perhaps too high cpu volts but I wanted to run quick and dirty without bsod'ing. Booted right from bios at 8.5x545 :eek: No clockgening tricks or exotic cooling. :up:
4.6Ghz @ 1.7v NB and cpu vcore @ 1.520v
http://www.hostthenpost.org/uploads/...a6886c85b8.jpg
4.63Ghz @ 1.7v NB and cpu vcore @ 1.568v
http://www.hostthenpost.org/uploads/...acae25b2c3.jpg
Everest shot showing PL @ 12, I could run 11, but like I said, quick and dirty.
http://www.hostthenpost.org/uploads/...72aa8a7743.jpg
Alrighty.
What bios should I use for my EP45-UD3P ? I have F4 now but is there some of the others that are better for OC?
@Zucker, Not too shabby :up:. I would love to see what that board can do with DDR3 in it. I think you should pick some up! I would go straight for some low voltage CL8 or CL7 dual channel kits made for i5 or i7.
At 4 GHZ (8x500) my DDR3 system seems "smoother" than my DDR2 system. Even though my DDR2 system will beat it in all tests and benches and is faster, the DDR3 just feels "smoother" with less "lag" if that makes any sense. I think PangingIII experienced the same feeling as well between the P45 UD3's...http://www.xtremesystems.org/forums/...postcount=2641
Thanks, mate. You have no idea how badly I want to upgrade to DDR3. :up: I know the setup has a lot more in it, but funds are hard to come by these days so I've pushed that away for the time. I have nothing but great respect for this combo baord :clap: With DDR3, I'll be in computing heaven. :up:
My comments were rude and I apologize to Hoss for them. I shouldve phrased it differently.
I'm not the only one who needs to chill, your harsh comments are unwarranted and unnecessary also.
Fact still remains however...saying that my NB is warm and now its not bc I put a fan on it, how does that help? Now if, my NB is hot, I keep getting random freezes, I put a fan over the NB, now its cooler, now I dont get freezes...thats results that actually mean something.
I appreciate you posting your results Zucker, thanks.
It's only money. :D Grab that credit card out and look here
:welcome:
I do want to say I'm not here to call people out, but as you have admitted, your response was uncalled for - especially when he answered your call for help and gave you excellent advice. May be you wanted him to spell everything out even though imo it seems straight forward: heat + cool air = cooler chipset. :clap:
Anyway, I'm sorry if I sounded harsh myself, but your post was begging for a spanking. :p: Accept my apologies, and goodluck in your clocking adventures. :up:
Looks good; I plan to put this chip under water, as well as upgrade my psu and etc. so it needs some planning :yepp: I'll also probably go 4GB to max the two slots designated for ddr3 on the board. I'm currently trying to hold 4.4Ghz stable, but I'm sure my psu is no longer up to the task as the +12v rail (35AMP Total) is dropping all the way down to 10.70v @ 1.3920v :eek:
Everest bandwidth
http://www.hostthenpost.org/uploads/...a714699dec.jpg
SPi 32M Run (8.5x518, PL9 1:1)
http://www.hostthenpost.org/uploads/...1e53e656ba.jpg
I just did mate, no need to be rude on this guys are very good ones, most of all helped me on all situations and some of then sent me things to my country where i cannot find anything good...just have to wait a bit and do tests on your own also, not every mobo its the same, not every chassis has the same air ciruculation and also temps on every room...
Cheers :up:
Sergio
Hi. What's the maximum voltage for daily use on GSKILL PI 1200 DDR2 whitout active cooling on them and what freguencies should I expect from them?
Here is my 24/7 Work PC setup. Not bad for a $99 mobo and $110 CPU.
http://img260.imageshack.us/img260/4...pc247setup.jpg
