Could u post some pics?
I only have an old pic (no camera) right now, it looks the same now except for BallistiX that replaced the Samsungs...
http://img527.imageshack.us/img527/884/img3550xe6.png
It's because of all the wires in front of/under your graphics card. 900's aren't very cable-management friendly when they're unmodded, especially when you don't have a modular PSU. Are the three exhaust fans really necessary?
Little update, some cable management in the lower section. Need to get my tripod piece back from my friend.
http://i7.photobucket.com/albums/y26...e/IMG_3180.jpg
here its mine :D
Just bought my new xigmatek DK its looks and works really good ;)
nice warlock, its nice to see more spedo's out there, dont think of that in a gay way :D
I just broke a fan blade off one of Scythe Ultra Kaze 3000rpms :(
I had it on my IFX-14 and the fan wasn't starting up. I restarted a bunch of times and it still didn't start, so I took it off and up it on top of my Antec 1200, i didn't unplug it cause the plug was on the cable management side of my pc and i'm lazy. So I left it plugged in and sat it on top of my case. The when I started the pc back up, guess what the **** fan started this time and it hit the my case and broke a blade off :(
Is it normally for a fan blade to break that easy?
If it's a 3K Ultra Kaze it wouldn't surprise me. The plastic they use for fans is really stiff and brittle. I broke the 200MM fan on my old 900 when I accidentally stuck my thumb into it.
I forgot to mention it was on a fan controller and was running at 1600RPM.
Also my Delta fan hit my case a while ago @ 4600rpm and it only made little chips on 3 blades.
Well different companies, different plastic. Just try to keep things away from the blades :D
Still didn't get my tripod piece back, but w/e.
http://i7.photobucket.com/albums/y26...e/IMG_3202.jpg
What fans?
Mine? The two front intake and CPU are low-speed Yates, rear exhaust is a S-Flex 49CFM, and up top I have two Silverstone FN122's. In the lower section I have a 30 CFM Scythe fan that looks like a S-Flex, but has a sleeve bearing. Exhaust is two Thermaltake 80MM fans that I removed the LED's from.
Nice clean rig, you must have a pretty good camera or awesome lighting too cause those pictures came out great.
I've posted this picture before but I have no new ones and I wanna post again :( :p
http://i54.photobucket.com/albums/g8...2/IMG_1682.jpg
http://i54.photobucket.com/albums/g8...IMG_1669-1.jpg
3 SFLEX 1200 RPM in the front
3 SFLEX 1200 RPM in the middle
2 Arctic 1500 RPM in the rear (these things push serious air)
http://img.photobucket.com/albums/v2...k/IMG_2867.jpg
I ran out of black zip ties. :(
http://img.photobucket.com/albums/v2...k/IMG_2863.jpg
A look from the rear.
http://img.photobucket.com/albums/v2...k/IMG_2865.jpg
Close up shot of the HDD suspension bike tubes.
http://img.photobucket.com/albums/v2...k/IMG_2866.jpg
It's not super quiet, but it's consistent. Most of the noise's from the Arctic fans pushing God knows how much air around. :D The raptor's aren't half as annoying as when I used the old Stacker HDD module though.
2 "Tommy_Hewitt" : new AMD build ???? =)
Nice image tommy but one question
Was there any room inside the case to hide/route the 24pin besides making it in front of image across the side of the 5.25 & 3.25 inch bays?
on a side note:
So how's the GPU cooling round up going for silenthardware.de?
Tommy Hewitt Which is your motherboard?
nvm
/me learning how to use wrapping paper as a background w/ help with Mr. grey card
http://www.hostthenpost.org/uploads/...bcb8b2e9ad.jpg
http://www.hostthenpost.org/uploads/...14c672966f.jpg
WAHH!! I will miss him :( he is being sold off
http://Ar3s.fileave.com/temp.jpg
switched from the tj-09 to a tj-10
Not the best sight in this threat, but it's a little old two..
I got a pair of ram, and 2x 4870X2's since the picture, but the mess is still the same.. I'll get it cleaned nice 'n' tidy very soon :)
http://img413.imageshack.us/img413/717/02012008074.jpg
god i need a dang new comp.
