http://mitglied.lycos.de/coolinglimi...er/Cooler3.jpg
That is unreal!
That is unreal!
/me drools
That is some might fine work there, isn't it?
I just had to share it.
Originally Posted by death metal
You are welcome.
All of our thanks go to they guys that have done the hard work of identifying these chips.
The rest of us are just out on a hunting expedition.
Fed ex came. so, I will have the twinmos SP 512 sticks and my 2nd 256 stick when I get home! Everyone let's just take a moment for a silent prayer to the overclock gods.
Sorry dude, I'm saving all my prayers for mine! :D ;)Quote:
Originally Posted by trans am
Seriously though, good luck with them :toast:
Next step is human sacrifice. :eek:Quote:
i wish the best! :toast: :toast:Quote:
I edited the first post so that we have everything tha is confirmed so far on what chips to look for!
- 2 DotsQuote:
- AA4T
- 2 Metal dots on both sides
are correct
but, the ram doesn't have to be speed premium ! I have standart twinmos ;)
and they aren't only 44D and 50D. mine are 60D :D
I would say speed premium after week 46 2004Quote:
Originally Posted by X-GeN
so how does mine do over 265mhz 2-2-2-5 ?Quote:
I'm saying if you want the chips on speed premium look after week 46. this could be when twinmos decided to use utt on the speed premium series.Quote:
ok now I understood :DQuote:
hehehehe, I still have those Micron sticks in my draw... actually trying to sell them now that I have VX.Quote:
Originally Posted by Reefa_Madness
this is what it's about for those of us without piles of coin though.... wait for the "budget" series and pray for a gem!
Good to see you again bro :)
Originally Posted by Rabbi_NZ
Word!
I have the money, but it's so much more rewarding finding inexpensive products and making them perform on par or better than the pricey components. Isn't that what overclocking is in the 1st place?
Yes it is...
here's where i am after 1 night of burn-in :D
EDIT: This is from the link you posted earlier in this
thread(Newegg)
EDIT#2
here's what i got...PC3200-256(DDR400)U-Dimm 184 PIN
Model# TMSP400/256
I'm just assuming that "U-DIMM" means UTT/Winbond ???
how many volts? this is 1 256 stick of speed premium?Quote:
Originally Posted by seldomsean
Im burnin with 3.10...Quote:
And yes this is the same 256Stick you first recevied
EDIT: See my post edit for the Model#
@ seldomsean
O/T, what is that funky taskbar in your screen shot? :slobber:
looks quite smart, I'm not sure if i'd use it myself though
What is the max you found? I started at 3.4v@250mhz and worked my way up to 270mhz, then backed it down to stable speed od 267 and then looped memtest86 for 24 hrs for burn in. I'm anxious to see what your max is with the same configuration. We are both using the same boards.
Is that some kind of Nintendo Super Mario task bar?
I got my final response form ADATA....
"Nope, all our DDR modules have only one small circle mark at the bottom
right hand corner of the IC. I checked the DDR 333, 400 modules (128,
256 MB)."
Stephen Su
A-DATA Technology (USA)
I'm sorry for asking so many times, but does anyone know where to buy TwinMOS memory in Canada? Duty from the US is killer...
EDIT: I've found these cheapo memories (I've read this entire thread, but I'm still a little confused about where Kingston Value stands.)
512MB PC3200 Kingston ValueRAM at NCIX.com (CAS 2.5 version)
512MB PC3200 Kingston ValueRAM at Tigerdirect.ca (CAS 3 version)
512MB PC3200 Infineon cheapo at NCIX.com
Infineon has the rights to Winbond's chips, right? Is there a chance that there may be Winbond UTT on their OEM stuff?
I'm just throwing ideas around here... I'd really like to hear if anyone knows where to get TwinMOS stuff in Canada. I'll do some more Googling and see if I can't find a source.
ok two of my friends already got winbond UTT from the speed premium :banana: :banana: :banana:
lucky them.... :toast:
http://www.geocities.com/nastechxtre...z_2225_mem.jpg
http://www.geocities.com/nastechxtre...636_resize.jpg
http://www.geocities.com/nastechxtre...med_resize.jpg
I found a bunch of twinmos mems new on ebay. Maybe find some and ask seller about circles. As far as Canada goes, I'm not much help. Why not contact Twinmos and ask if they have Canadian resellers.Quote:
Originally Posted by mcnbns
I think that is what's is waiting for me at home.Quote:
Originally Posted by tictac
@ trans am...Quote:
No it's not Nintendo but now that you mention it "Sure looks like it"
My 8year old put that there :D Well i haven't tried to find my Max
yet but i will do it now ;) Also change out the "Theme" :eek:
I will post a screenie of what i can get(Max)
In the meantime have you seen this thread...http://www.xtremesystems.org/forums/...ad.php?t=49660
267@2.0-2-2-x Dual Channel(939) :banana:
EDIT: Ahh TicTac beat me to it ;)
seldomsean,
up your vdimm to at least 3.2v to get those modules clocking right... my VX did jack until I gave them over 3.0v... 3.2v is when they made the biggest MHz increase.
