How come with 0704 BIOS when I set my voltage to 1.3 for CPU and 1.65 for DRAM it doesnt change them unless I manually do so in Windows? Should I go to the latest BIOS to fix this?
u can OC to 4.6 same baam :) but as i told you any new BIOS for me introduces some things i dont like so i prefeer to go 0095 for my rock solid 5GHz HT 2800Mem so my SLI of GTX680 pumping fire at 1320core :)
i tried every BIOS of M5F i stood with that
but if you are new to OC and you want easy go for that AUTO OC 4.8 that will be good either way :)
cheers !
Sergio
Hi Sergio, I use 0095 bios on mine Maximus V Formula, but I don't see option for booting into optical device (pressing F8 or in bios), on AHCI mode.
Putting bios 1.4 or 1.6, the option reapear.
At you is the same?
Optical device (DVDRW) is put on Intel Controller, on S-Ata 2 port.
@raja ihave a problem my mobo stucks at 4f and reboots after 4 f and reboot
you can help me?
FIXED
strange when i flas 0095 bck cant be changed mei no works why?/??//
little off topic, but not by far
what are the ic ?
CMT8GX3M2B2133C9 rev4.13 ( double sided modules on each stick )
- Two matched 4GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2133MHz performance using 4GB of memory
- Ultra-low 9-11-10-27 latency
- Intel XMP (Extreme Memory Profile) Support
- Airflow Fan
- Density: 8GB (2x4GB Module)
- Speed: 2133MHz
- Timing: 9-11-10-27
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50V
http://www.memorybenchmark.net/ram.p...C9+4GB&id=1437
IC is the manufacturer of ram chip like Hynix,Elpida,Samsung,etc
some chips are better to OC, another are better to tight settings, some ones loves scaling with vcore ...
found my answer on the internet : Samsung ic
http://kikicoco1334.blogspot.fr/2012...rformance.html
mobo now stucked at code 78 tried another memoery vga reseat cpu but same issue another one rma in one week
i will go to buy another brand mobo
are u using ROG Connect to flash ? i saw there was a method to revive not sure if was that code but worth a try it was on this web or maybe you can ask shamino there
http://kingpincooling.com/forum/forumdisplay.php?f=23
cpu dead at stock settingd
checked with microscope and tested another cpu (crappy pentium) and boots fine
test cpu on another mobo and same issue 78 error code,cpu is dead R.I.P
6200 3d on cascade -120
has any1 found a way to make AC3 play with the optical in on the extreme?
M5 1707 bioses. GeneV, Formula, Extreme included. Multiplier issue fixed, Fsb 100.00Mhz fixed, and other things......Thanks Shamino :)
http://www.mediafire.com/?28rhmf7drn7zutk
1707 installed...all fixed thanks
Sadly, he's still got lots of work left, every single ASUS Z77 board needs this fix, ROG and non-ROG. More and more users come on our forum now complaining about it.
But I knew Sham would get it fixed, and because of that, he's one of the most important people in the industry right now. I hope they pay him very very well.
