I7 3770K Batch L211B472
5GHZ 3D vantage watercooling
http://imageshack.us/a/img338/5322/vantage44344.jpg
http://hwbot.org/submission/2322663_
3224B047 *A2913
2770 max imc, 1.46V 5Ghz...back to its box, next...
3224B259 *A1628
5Ghz 4C/8T 1.46V air, IMC absolute max 2970 and benchable @ 2600 tight timings...
With Hynix CFR
http://img84.imageshack.us/img84/1132/screenshot135.png
PSC
http://img703.imageshack.us/img703/4...enshot136o.png
Dumo, am i right in assuming tightning down the timings lowers the max clocks for the IMC? I haven't had the opportunity to try this myself but i think that is what you are saying, right?
Zeus, imo it depends on the cpu. Some can do imc 3000 32m with relax timings but went beserk @ 2600 tight timings like this one...
3226B953
http://img515.imageshack.us/img515/3...enshot028k.png
Hey dumo do you consider this very tight?Interesting enough,testing single channle 8-10-10 2400 is fine,but dual gives error.Same at 9-11-11 2600,single is fine,dual gives error.Lots of volts in VCCSA helps,e.g 1.3 is more stable than 1.2 but still gives error like round 20.If running near to 2800 it will not give error,it just freezes...
http://www.abload.de/img/500953jjb.jpg
3570k under air cooling 5000mhz prime
Nice attempt... Pls try v27.7 with AVX instruction :D
ftp://mersenne.org/gimps/p95v277.win64.zip
yes have 27.7 on my pc!
with have a german forum bechmark list based on the 26.6 prime
have benched it with 27.7
have only scythe mine coller on it with 2 fans!
think 5 ghz on air is the maxiumum you can prime!
beste air cooler what i read is the Phanteks PH-TC14
here with 4900 an 27.7
http://www.abload.de/img/4900mhzvdcal.jpg
http://www.abload.de/img/4800primenirz5.jpg
I never have any luck..even when I get the good batches :(
Using XSPC watercooling, Maximus V extreme
3224B167 - 4.8ghz, 1.475v. Can't get 5ghz stable. Gives typical BSOD that means more vcore.
3224B220 - needs 1.525v just to get into windows at 5ghz, but gives strange memory management error BSOD before that. Could this just have the worst IMC ever?
3226B939 1.27V 4c/8t on H20
http://img853.imageshack.us/img853/9...nshot044bj.png
I have same batch 3226B987 look my pics on this thread , is very lower Vcore clocker...but unfortunately is Hot days on Buenos aires today 35C! tomorrow 34C i can't push it more with this hot days
http://thumbs.subefotos.com/d078cc74...47c3571f1o.jpg
Awesome chip Dumo! How much vcore to run a couple passes of linx?
3570k L211B226 PCB SN 0053 best batch
PSC DUAL CHANNEL AIR 3000+ mhz http://valid.canardpc.com/show_oc.php?id=2569726
MFR-PBC DUAL CHANNEL 2933mhz Air http://valid.canardpc.com/show_oc.php?id=2571034 2933 boot
MFR-PBC SINGAL 8G Air 11-14-14-35 1t 3000mhz http://valid.canardpc.com/show_oc.php?id=2558614
SAMSUNG 8G*2 HCH9 2640MHZ http://valid.canardpc.com/show_oc.php?id=2558890
SAMSUNG 4G HCH9 3100MHZ AIR http://valid.canardpc.com/show_oc.php?id=2575543
SAMSUNG 4G*2 HCH9 3073MHZ AIR http://valid.canardpc.com/show_oc.php?id=2575694
@LN2 6.887G 4CORE http://valid.canardpc.com/show_oc.php?id=2549013
PSC 2933 1T BOOT 11-14-14-40 1T
http://ww3.sinaimg.cn/large/6b695c7fgw1dymybksjdhj.jpg
MFR PBC 2933 2T BOOT 11-14-14-40
http://ww2.sinaimg.cn/large/6b695c7fgw1dykkwejyo1j.jpg
I don't think there is a best batch with IB. Just seems to be a luck of the draw found on any particular batch order.
My IB 3570k batch 3204B958 which I purchased at release date back in May does 4.5GHZ at 1.15v with Gskill Ram at XMP settings of 2400mhz CL10. With water cooling.
http://minidriven.com/BlacknBlueforI...i53570kIHS.jpg
To me it looks like a good set of ram and sub ambient temp cooling is needed to see max performance of any IB cpu.
3224B259 *A3129 fully clothed on H20
http://img560.imageshack.us/img560/2...eenshot066.png
Great chip bud !!!
Very nice chip, my latest totally sucks in V compared to that one. Binning continues.
It's not 1.32 vcore but for cheap WC ( antec khuler 620 + Spring time on Buenos Aires + Full Bank Dimms ) I think is right
3226B987
http://www.firegoon.com/images/mru1ccr.jpg
^^Awesome cooler, I used the same:up:
Thanks Dumo another run
Cinebench running
http://www.firegoon.com/images/vcxqhnn.png
Cinebench finished
http://www.firegoon.com/images/nj7w63q.jpg
LinX running
http://www.firegoon.com/images/3aqt41f.png
LinX finished
http://www.firegoon.com/images/egy8spx.png
