Well its nice to see people with these insane overclocks!! It encouraged me to overclock with my pair in SLi (Palit Sonic Platinums) and I think I've hit a brick wall, but a wierd one. I've searched and searched and can't see what I'm doing wrong.
My max clock right now is 871/1742/2098(1049)/1062mV
and the moment I go over that I see maybe one 'red dot' or two in Heaven benchmark and I know its not stable, so what do you do? Increase the voltage! This however presents a new problem, the moment I go over 1062mV Voltage the card while benching will eventually do the following:
Ramp up fan speed to cool down card but a few seconds later, BAM, Black screen, then the fans will go even faster probably to 100% and the machine will stay like this.
In this state the PC will still be running in the background, HDD spinning and Led flashing indicating usage, if music is possibly playing it will continue to play such as the heaven benchmark music which confuses the S...ugar out of me!
What I did notice was it may be linked to temps. Over 80c and it would 'black out' on me. Ramping the fans up didn't change the temps much so it may be that. Another senario could be the lack of a VRM heatsink, I tried to solve this by cuting a small part of a XBOX 360 GPU heatsink I had lying around(not that everyone would:p:) and covering both VRMS with it and the result of that is I found generally in games the fans didn't spin up as much, especially in crysis! Result you would think, no. 880Mhz showed the red dot I talked about but I didn't hear the fans as much, when seeing the red dot I instantly stoped the bench but upon returning to the desktop I noticed the temp was 77c at that point but up to that point the bench was fine, hmm :explode:. Third and last senario I could think of is the power supply: its an XFX 650w XXX PSU and Supposedly my whole system using the online calculator consumes 590w and although it includes my CPU overclock it doesn't take into account my 460 overclock but then again why would the rest of my system run if the PSU was overloaded?
Two other things I've noticed is that some people reach 90c no probs and one person with the same card as me got to 900 core. Also I'm not sure if it was this forum but I think I saw someone say that they're only stable for their clocks at 60c.
Any ideas?:confused: I'm going to go watercooling soon so I'm hopeful for that, my load temps with the max clock is around 77-79c
