Hi all,
I just discovered that I can't start WebBIOS anymore.
I do not know since when / what this is, since I have only used WebBIOS during the initial setup of the RAID5
A few weeks ago I have updated my LSI's firmware, driver and all LSI software to the latest version (still the latest now). MSM and the RAID5 kept on working great...
What happens is:
* I boot my PC
* I press CTRL-H when it sais I should press CTRL-H for WebBIOS
* It quickly shows the message "WebBIOS will be executed after the POST is over"
* It proceeds to boot but never enters WebBIOS
First it just proceeded by booting Windows, then I tried changing my Gigabyte onboard controllers from AHCI to IDE (the AHCI screen of these controllers came AFTER my LSI boot screen), then I disconnected my SSD (OS drive), then I disabled all onboard controllers except ICH (which had nothing attached) and finally I tried all possible combinations of this... Nothing helps...
If the OS drive is attached, it simply boots the OS... If the OS drive isn't attached, it simply stops booting after the POST (blinking cursor, no error at all)
I tried starting the pre-boot CLI, which works (but it also doesn't start post-POST, like the WebBIOS)
Does anyone have an idea how I can "fix" WebBIOS?
edit1:
Only found this similar issue:
http://www.fixya.com/support/t175482...web_bios_start
Their solution is to remove HDs from the onboard controller, but I already tried that and it didn't help for me...
I just also tried the following:
* Removed DVDROM and SSD (so that there are no devices attached to the onboard controller)
* Removed the 2 new HDs from my LSI RAID controller (so that only the 4 HDs are attached that I initially setup using WebBIOS)
* Loaded fail save settings in the BIOS (although I didn't overclock yet, this should reset all my "optimizations" to the most default BIOS settings)
The above also did NOT help :(
Anyone still has ideas?
edit2:
I just had a very long call with LSI support (friendly helpful people btw)
He thought it had to do with insufficient memory to load WebBIOS (a server mobo has more memory or something?) and suggested to disable as much as possible in the MOBO BIOS.
So I loaded fail safe settings and then disabled anything I could (including disconnecting as much hardware as possible), but it didn't help either... :(
Then he suggested to re-install the old firmware of my RAID Controller, since the new firmware has a lot of new advanced features that I'm not using (related to SSD), it might help free up some memory...
I told him I'll get back to him once I tried that.
So I just tried it, again including disabling / detaching as much as possible and this time I also tried loading "optimized default" first...
Again this didn't help... :(
So I'm stuck once more...
actually the only thing that is different now compared to when I used WebBIOS to initially setup the RAID5 is the BIOS of the MOBO I Think (F7 vs F6)
I'm not sure if that is so easy to roll back, since I do would like to keep my current F7 settings and I'm afraid rolling back will erase those...
So does anyone have an idea what is going on here?
Does anyone understand which memory the LSI support guy suggests is insufficient? Which memory is being used to load such post-POST BIOS applications? How do there post-POST (but pre-WhatEverIsSelectedInTheBIOSAsBootDevice) BIOS applications actually work? Is there a name for such applications (so I can google for it to find out more about it)?
Thanks!
