No only raise the cpu voltage to 1.55v, Only raise nb voltage if you are going past 2300-2400 maybe just a little for stability ...you need to try it out and see if it helps. If you raise the nb voltage and it doesnt help lower it dont leave it and keep adding volts.
Did you figure out what is your highest overclock on just the cpu?? You need to leave everything at stock and keep raising the multi till you need to add voltage to the cpu, add voltage, then up the multi again till you need to add voltage. At around 3.2ghz start testing using games 3dm06 and super PI if they pass without reboot try a little higher 3.3ghz then again try games 3dm06 and super PI. stop when you dont want to add more voltage to the cpu. Watch temps......try it out:up:
