You can always step down a few notches on Vtt you know. Higher isn't always better, just depends on the FSB frequency. Some frequencies need a lot, others need less, then a few MHz beyond might need lot more or less. Just depends its a variable factor and all you can do is set GTLs to 1 set of multipliers, ie 0.67 and 0.63 for RF and then try raising and dropping Vtt to find a point where the failures occur after the longest period of time. Then from there try and leave Vtt and fiddle with GTLs and see if you can stabilize it, if you can't drop Vtt by 0.02, and try again, if not raise by 0.02 above your set value and try again. and so on. It's lots of trial and error mostly, but you'll get the hang of feeling what it wants after a while.
