Tested my rampage Extreme and my new Wolf as well yesterday.
Some screenes for you.
90031p with fully aircooled. Single HD4870 with stock cooling and no voltage modifications :rolleyes:
http://img294.imageshack.us/img294/9...m01hugarl0.jpg
620FSB Spi1M. No tweaks.
http://img131.imageshack.us/img131/6...pi1mon8.th.jpg
5000mhz Spi1M. No memory tweaks. No Spi1M tweaks. Just a run.
http://img258.imageshack.us/img258/6...328sur3.th.jpg
600FSB and 4500Mhz @ 1,325V Vcore, bios boot. Stable.
http://img180.imageshack.us/img180/9...lne1bb4.th.jpg
Sry, didnt want to waiste time with Prime95 longer than that :D
CPU cooler is Scythe Andy Samurai Master.
HD4870 is on stock cooling and with asus top bios on her.
Mem is OCZ PC3-12800 Golden edition 2*1gb sticks what i confermed to be D9JNM :p:
True that Rampage Extreme dont get well along with any decent micron ddr3 chips. Sometimes its fully stable and then its not posting at all.
Mine does not do 1T at all. At least i can do 2000mhz 7-7-7-17 with 2,18V on sticks :ROTF:. I dont run it usually even for top scores because 2,18V is really too much for ddr3.
Im using 0301 and 0403 bios. Thiese are the best so far. Both dotn work at 1T command rate tho :down:.
Im Happy with my second E8600. It turned out to be good chip. Have wasted tons on money searching for that. I have had E8500, E8400, E8200 etc :D
Anyway. I hope that screenes help someone to get 600FSB+
you dont need to adjust GTL voltages really. They are very tricky and usually just lower your max FSB. Leave GTL voltages to auto. Turn out all crap. But around same voltages as i did on MB. (see last picture)
Put fan on NB because it gets really hot even with 1,5v.
If u have nice CPU you should get to 600FSB easily.
Cheers.
Kris.
