Nice analysis going on although it's becoming very offshoot to what I stated and did. Scaling wasn't shown in the true mathematical sense, little time to do it. This was data I already had for some time now, copied it over. All that was meant to be shown is the % change in SPI 1M times as frequency rises above the 1800MHz time, which is projected as 100%, or stock. Call is 0% if you like and anything on-top is the gained percentage.
K10 comes in where people state affirmatively that something they do not own nor have seen perform from a released product, cannot react in a certain way, for whatever musings. I've seen erratic jumps before in processor performance, and I'm showing one of them right here.
It''s not to "argue" anything but a viable possibility you cannot on any grounds reject yet. You have no evidence to. Or we'd like to see it. :)
No typo, I clearly state it's experimental results. I predicted linear scaling, as most people would. But investigation speaks otherwise - something I cannot explain but I experience.
Conditions are exactly the same for all but >3500 (unstable), in fact I'm sure they were ran one after another on the same day, with minimum services/processes running in the background. One thing I clearly stated I didn't and couldn't do, is keep the memory asynchronous. RAM timings/divider is kept the same. But the rest I'll show it you and I've repeated it time and time again from around 4 months back. All of the data stands final. ;)
I'll try and find what I still can, one second. Hmm... there's data missing here. I only seem to have a few of the run results saved but have more info in the text file saved instead. Anyway, the interesting ones are all still there, the rest of the missing +100MHz sampling points are progressive and linear as you would expect and I'll try finding them on the other drives. Here ya go.
1800MHz = http://img212.imageshack.us/img212/5...00spi1mlx8.jpg
2000MHz = http://img406.imageshack.us/img406/8...00spi1mus3.jpg
2100MHz = http://img510.imageshack.us/img510/6...00spi1mgc7.jpg
2200MHz = http://img205.imageshack.us/img205/1...00spi1mwn9.jpg
2300MHz = http://img250.imageshack.us/img250/8...00spi1mqk4.jpg
2500MHz = http://img508.imageshack.us/img508/7...00spi1mhm8.jpg
2600MHz = http://img209.imageshack.us/img209/3...00spi1mlb0.jpg
2800MHz = http://img510.imageshack.us/img510/2...00spi1map4.jpg
3000MHz = http://img515.imageshack.us/img515/1...00spi1mod1.jpg
3200MHz = http://img265.imageshack.us/img265/4...00spi1mnr5.jpg
3300MHz = http://img250.imageshack.us/img250/8...00spi1mzk4.jpg
3360MHz (3400 is the same) = http://img210.imageshack.us/img210/4379/spi48qg8.jpg
3500MHz = http://img250.imageshack.us/img250/2747/sp47dm3.jpg
3500MHz is quickest = after that, there's hardly any change if the processor runs it (memory bottleneck). If I had similar memory and system now, I'd repeat them now again just to refresh, but I don't and I didn't know this was coming to prepare but just did it for my own personal investigating back then.
BTW, science doesn't equal "we expect this and this all that can be true." Broken logic is to expect linear scaling and when something other occurs you start the conspiracies. Science broadens your horizons to accept observational finding, like the new colossal area devoid of matter found in space, even devoid of dark energy, which was NEVER predicted nor expected at those sizes and changes acceptance of many beliefs and idea's held by physicists beforehand.
Scientific experiment = controlled conditions + variable factor + experiment + observation + repetition + results
I've just given you results of some of my findings, enough for a genuinely interested person to see what's happening for themselves.
Conspiracy theories and conjectures will get one no where. All you have to do is ask for evidence before the insinuating. :)Quote:
The other is 3301 or 3201, I looks like he ran the same run twice at the same frequency but recorded a different speed. Here is a plot of his SP1M time vs frequency
That's what you want to believe Jack, not what the evidence shows. I'm sorry but you haven't proved how my finding ties in with your belief.Quote:
In short, he data shows nothing but a handful of mistakes and that indeed SP1M scales linearly with clock speed.
