Where do you get your E8500 E0s
Hey guys. First post here :D
Just wanted to ask where do you get your E8500 E0s from?? I want want and all my local stores don't have it. I saw some forum sites that sell E8500 E0, where I can order online.
Anybody else knows a store where I can order E8500 E0 guaranteed, to Canada?
Edit: I've been siting here with all my other parts (Biostar Tpower I45, 2GB OCZ Reaper HXC, Corsair HX520 watts, and antec 900 and Ati Radeon 4870)
2 Attachment(s)
first attempt at 4.5Ghz on Air silent
Got my Q827A E8400 cooled on Xigmatek S1384/ Maximus Formula stable on 4Ghz @ 1.240V around 42 Degrees stressed :D (auto voltage)
Cant go higher because mem wont go over 920, will get new ram soon to hit 4.5+Ghz:rolleyes:
(i dont like overvolting ram at all)
I want to thank everyone on this threat, its realy high quality information and helped me alot :up:
p.s Just cant compare my E8400 to my AMD X2 5000+@3.2, AMD is really far behind on performance and temps as it could not handle most games maxed with my 3870X2, but the E8400 can for example :yepp:
1 Attachment(s)
Correct me if im wrong but
@OCX600RR;
I think that can be a problem with ddr2 800 because the speeds u c here (+-500mhz) are half the effective speed, with wich the speed is usually indicated.
PC6400 will run on 800Mhz effective and oc to +-900Mhz, but CPU-Z will say it is running at 400Mhz (800) or in my case 440Mhz wich is 880Mhz effective.
And because the RAM cannot run slower than the FSB is running you will have this:
CPU: 488*9=4.4Ghz
RAM: 488*2=977Mhz effective and i think that will be a very high oc for PC6400 800Mhz RAM but maybe possible.
For 45 euro you have 2GB 1066Mhz RAM wich will get you there i guess:)
I learned this trying the exact same thing with DDR2 800...:p:
(my previous post)
E8400 E0 now or E8500 E0 later?
Ok so guys. Should I order E8400 E0 from tank guys, or wait for a E8500 E0:(:(?
