this is my first liquid system (on the cheap side :D), I finished it yesterday, if you click on the photo you'll be headed to the thread in which I ask for some help with my temps :)
http://www.drusie.com/cesare/computer_bologna1_1024.jpg
Case Cooler Master 690 II advanced
Pump OCZ hydro pulse 800 L
single rad with a 140 fan adapted (cooler master 1200RPM) @12v
dual rad XSPC RS240 with two Thermaltake 120 fans (TT-1225A 1900RPM) @7v
reservoir XSPC single bay 5,25
CPU WB Ybris eclipse
VGA WB Ybris ACS-G
barb fittings 1/2"
tubing 1/2" silicon
