As competition to Anvil's Intel 330, I present the Sandisk Extreme G25 - 120gig.
Sporting 128gig of 24nm Toggle NAND and the sandforce controller, Sandisk has created a little ripper of a drive at a very competitive price. Unfortunately, due to the nature of the sandforce controller, and the configuration of NAND in this drive, speed will be a little bit slower then the Intel 330. However, it is also a bit cheaper, and can be gotten in larger sizes then the intel 330.
Initial SMART values
Attachment 127367
Benchmarks
Attachment 127368
Attachment 127369
Running ASU endurance test
Attachment 127370
Notes: I does appear that the sandforce controller can manage bad blocks .... loading the initial data on the drive caused a couple of bad blocks to appear. This drive must have escaped the factory before it's bad blocks where fully found.
Edit: I am using same specs as other drives, but have 64gig of static data to match Anvil's 330.
