my new air set up :up:
The best buy rocketfish weighed a lot less and proved easier to bring to LAN's. But it just didn't cool or dampen the noise like my old stacker w/ dirt bike tubes used for the suspending the drives. It also had a single exhaust and less ventilation up front. It might be old, scratched, dinged, and heavy, but I love my stacker! :up:
http://img.photobucket.com/albums/v2...k/IMG_2776.jpg
http://img.photobucket.com/albums/v2...k/IMG_2777.jpg
http://img.photobucket.com/albums/v2...k/IMG_2778.jpg
wow, seems like the air cooling forum is getting cold these days
@Krame
Man that case is so neat and clean dude great job:clap:
@Krame Now that's a beautiful case dude.
Amazing :clap:
great ;)
Krame: awesomely clean, very nice job.
It has been a while since I've been on air, so I figured I'd so off what I have currently.
Going to replace it in a week or so once I get my Killcoils from PetrasTechShop.
http://img204.imageshack.us/img204/6913/p1010922bc1.jpg
http://img204.imageshack.us/img204/9383/p1010882if9.jpg
http://img217.imageshack.us/img217/8886/p1010906ju0.jpg
http://img147.imageshack.us/img147/8812/p1010888gt4.jpg
Didn't bother trying to get any angled shots.
Kit lens:
http://farm4.static.flickr.com/3365/...4d861f9c_b.jpg
http://farm4.static.flickr.com/3394/...46e67fe7_b.jpg
EF 60mm Macro:
http://farm4.static.flickr.com/3406/...2f34d60e_b.jpg
http://farm4.static.flickr.com/3536/...b7f7239b_b.jpg
SimpleTECH, could you please post a pic of the front with the fan controller? is it the basic version or the ACE version? thanks! :up:
It's the Scythe 'KAZE MASTER' 5.25" bay fan controller.
They released a newer version as well. But I still prefer the one I have currently, little more chic.
hey my friend..I did'nt know they came out with a newer vrsion?
I recently replace mine with new 1 cause fan controller #1 went out
completely it went blank nothing after about 10 months or so..i went
to mirco center and bought 1 returned the bad one as warranty return
in the same box and got my money back:yepp:
but here it is sitting up in my CM 590
http://img502.imageshack.us/img502/1328/pict0040lt2.jpg
Shot at 2009-01-27
evil-98 what cooler is on your graphics card?
It looks kind of like a scythe mushashi/ arctic cooling xtreme.
Hey jdmR, why would you put the Ultra Kaze as the exhaust instead of on the CPU? Usually 38MM thick fans have higher static pressure, so wouldn't it be better on the CPU?
after trying different set ups for the airflow across the cpu hs, i found that theres still a good enough amount of airflow with the way it is set now: intake-ultra kaze hsfan-xigmatek exhaust-ultra kaze. keep in mind that this is a direct air flow. i was also keeping aesthetics in mind as well as performance. i'll be aiming for a moderate 4.2 ghz on a e8400 so im hoping the temps will be fine
