I hope the M3P lives long enough to throw off the chart scale as well.
Todays update:
m4
986.4017 TiB
4151 hours
Avg speed 73.72 MiB/s.
AD gone from 48 to 45
P/E 17010.
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=492855
Intel X25-M G1 80GB
676.62 TiB
23462 hours
Reallocated sectors : 106 to 108
Available Reserved space: 78
MWI= 103 to 99
MD5 =OK
42.74 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=492849
Intel X25-E 64GB
181.15 TiB
550-30=520 hours
Available Reserved space: 100
MWI= 98
MD5 =OK
100.27 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=492851
B.A.T.
Am I imagining things, or did the M4 go from 33 erase fail and 0 program fail to 33 erase and 26 program failures like 4 days ago? Hmm. I wonder if that just means it just had to try a couple times to erase or program, but no blocks were taken out of service.
You have good eyes. I missed that one. It changed to 26 between 29th and 30th of may.
Just for amusement (and with no expense spared) a 4 GB unbranded USB drive. No SMART info. :D
Assuming 1,000 P/E cycles @ 2.5 MB/s it could in theory last 19 days.
Attachment 127302
A01,
Do you happen to know what manner of flash is up in there? I'm sure when it dies you can pry it open. All things considered, 2.5 Mbs isn't terrible. It's not much worse than the 32GB PS 100 Phison I tried.
Intel 330 120GB
109.25TB Host writes
Reallocated sectors : 05 0
Available Reserved Space : E8 100
MWI 89
[F1] Total LBAs Written 3579887
[F2] Total LBAs Read 22624 // a tiny movement
[F9] Total NAND Writes 78855GB
POH 290
MD5 OK
122.74MiB/s on avg (~195 hours)
Kingston SSDNow 40GB (X25-V)
1007.20TB Host writes
Reallocated sectors : 05 46
Available Reserved Space : E8 99
POH 9016
MD5 OK
33.39MiB/s on avg (~195 hours)
My Intel 520 is up and running again.
No issues to report with it after it's retention test.
Generic USB Drive – 4 GB
Writes: 186.34 GB
Average speed: 2.42 MB/s
(@ Christopher. Don’t know what NAND it is using, as it’s a sealed unit. Will take it apart to find out when it dies).
Plextor M3P 128GB Day 7
177,415.03 GiB
273.49 MB/s Average
181 Hours
Rellocated Event Count 0
Samsung 830 256GB Day 76
1,846,845.29 GiB
1,803.56 TiB
299.72 MB/s Average
1826 Hours
8020 Wear Leveling Count
MWI 1
6/0 Erase/Program Fail
Used Reserved Block Count: 12/24572 sectors
The two drives have been in the alternate rig for 6.5 days and their average speeds are doing well. ~300MB/s for the 830 and 273MB/s for the M3P.
Todays update:
m4
992.4243 TiB
4175 hours
Avg speed 73.85 MiB/s.
AD gone from 45 to 42
P/E 17112.
CE gone from 0 to 26 (29th to 30th of may)
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=493008
Intel X25-M G1 80GB
680.21 TiB
23486 hours
Reallocated sectors : 108 to 114
Available Reserved space: 78 to 77
MWI= 99 to 91
MD5 =OK
43.55 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=493007
Intel X25-E 64GB
189.34 TiB
574-30=544 hours
MWI= 98
MD5 =OK
100.24 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=493005
Mtron Pro 7025 32GB
I just started the test. The ssd has 47,5355 TiB of write before the test (based on the smart numbers)
ASU write o TiB (total 47,5355 TiB)
Host write 0 TiB (total 47,5355 TiB)
0 hours
MWI= 99
MD5 =OK
52.61 MiB/s on avg (after a couple of loops)
http://www.diskusjon.no/index.php?ap...tach_id=493012
I have a spare 4GB ADATA C906 USB2 stick, NAND is Micron 29F32G08CBACA, 10th 2011 manufactured.. I guess it's 25nm 3K P/E asynchronous..
http://www.abload.de/img/adatausbflashdriveusb1r7t3.png
http://www.abload.de/img/desktop_2012_06_04_000q70k.png
Stupid question perhaps but here goes anyway;
Looking at the charts in post 1 can I assume that if a given 60Gig drive reaches MWI in xTB written then the `120Gig version of the same drive should hit MWI in 2xTB and the 240 in 4xTB etc?
This is mostly true for most drives. Most drives use average PE cycle count to determine MWI 1, meaning a drive with flash rated for 5K PE cycles will consume 1 percent of MWI every 50 PE cycles. The 64GB Turbo I ran used 1 PE cycle for every 56GB written, so for every 2800 GiB written in the test the drive would reduce MWI by 1.
Some drives, like the M3P and the Octane, rely on reallocations to determine MWI, meaning MWI will never decrease until there is a block failure.
amazing the Samsung 830 hasn't slowed 1 bit.
Plextor has asked me to tell you guys if you had any questions to ask about Plextor products or wanted to ask Interview questions During Computex 2012 please post them here : https://www.facebook.com/photo.php?f...0952990&type=1
This your chance to put your questions to a senior member of Plextor's management.
Ask about products, the future of storage, or any other topic that you feel Agent Speed should interrogate them on.
Leave a comment with your question for a chance to win swag from Computex & Plextor
BTW Toshiba intros 19nm NANDs with 64GB version write speed of 240MiB/s
http://www.toshiba.co.jp/about/press...6/pr_j0401.htm
kaktus your usb flash pen is not aligned.
Writes: 390.34 GB
Average speed: 2.68 MB/s
So after 7 days I put the drives back in the endurance rig. Both drives' average speed is down by 5MB/s, and current speeds never quite get as high. Even with all power saving technologies disabled and on the same RST version, it's just not as fast. Almost, but not quite.
same MB or different?
Todays update:
m4
999.0270 TiB
4201 hours
Avg speed 73.82 MiB/s.
AD gone from 42 to 38
P/E 17225.
CE 26
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=493194
Intel X25-M G1 80GB
684.16 TiB
23512 hours
Reallocated sectors : 114 to 123
Available Reserved space: 77
MWI= 91 to 82
MD5 =OK
43.68 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=493203
Intel X25-E 64GB
198.28 TiB
600-30=570 hours
MWI= 98
MD5 =OK
99.73 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=493195
Mtron Pro 7025 32GB
ASU write 3.5641 TiB
Host write 6,3484 TiB
Total host write 53,8839 TiB
1 day
MWI= 99
MD5 =OK
47.73 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=493196
Intel 330 120GB
123.19TB Host writes
MWI 87
[F1] Total LBAs Written 4036763
[F2] Total LBAs Read 22624 // no movement
[F9] Total NAND Writes 88918GB
POH 323
MD5 OK
122.77MiB/s on avg (~228 hours)
1010.98TB Host writes
POH 9049
MD5 OK
33.36MiB/s on avg (~228 hours)
Both drives are now running RC2. (just part of testing, RC2 will be available tomorrow)
Attachment 127354
Plextor M3P 128GB Day 8
202,818.03 GiB
189.06 TiB
267.70 MB/s Avg, down from 273.49 MB/s in the other rig
206 Hours
Samsung 830 256GB Day 77
1,874,882.36 GiB
1,830.94 TiB
295 MB/s Average down from 299.72 MB/s in the other rig
1850 Hours
8141 Wear Leveling Count
MWI 1
7/0 Erase/Program Fail
Used Reserved Block Count: 14/28672 sectors
