Hi Guys,
i've recently upgraded from a w3520 to a 970 and would like to push it to the max :p
i don't know a lot about this, and this seems a good place to learn. i've been reading almost all pages and would like to share my settings so you guys can tell me if there's something i can change.
also i have 3x 470 and i dont have the ez_molex conected. even though i'm planning on doing it. i have a silverstone strider plus 1000w and have the two 8pin atx conected.Quote:
Target CPU Frequency 4500MHz
Target DRAM Frequency 1443MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
2D Performance Booster [Disabled]
CPU Ratio Setting [25.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
MPS and ACPI MADT ordering [Modern]
Intel(R) Virtualization Tech [disabled]
CPU TM Function [Disabled]
Execute Disable Bit [disabled]
Intel(R) HT Technology [disabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [disabled]
Performance/Watt select [n/a]
Intel(R) C-STATE Tech [disabled]
C State package limit setting [n/a]
C1 Auto Demotion [n/a]
C3 Auto Demotion [n/a]
BCLK Frequency [180]
PCIE Frequency [101]
DRAM Frequency [auto]
UCLK Frequency [auto]
QPI Link Data Rate [auto]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 6 [Auto]
RAS# to CAS# Delay 7 [Auto]
RAS# PRE Time 6 [Auto]
RAS# ACT Time 18 [Auto]
RAS# to RAS# Delay 4 [Auto]
REF Cycle Time 72 [Auto]
WRITE Recovery Time 10 [Auto]
READ to PRE Time 6 [Auto]
FOUR ACT WIN Time 24 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 1N [Auto]
Round Trip Latency on CHA 59 [Auto]
Round Trip Latency on CHB 61 [Auto]
Round Trip Latency on CHC 62 [Auto]
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 18 [Auto]
READ To WRITE Delay(DD) 7 [Auto]
READ To WRITE Delay(DR) 7 [Auto]
READ To WRITE Delay(SR) 7 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [X-Power] didn't see any diffence in overclock though.
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Enabled]*
Extreme OC [Auto]
CPU Voltage [1.4250]
CPU PLL Voltage [1.60325]
QPI/DRAM Core Voltage [1.3875]
DRAM Bus Voltage [1.60325]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage [1.20575]
IOH PCIE Voltage [1.57675]
ICH Voltage [1.20575]
ICH PCIE Voltage [1.57675]
*QPI Voltage OCP [Enabled]
*IOH Voltage OCP [Enabled]
*DRAM Voltage OCP [Enabled]
*QPI PWM Frequency [Auto]
*IOH PWM Frequency [Auto]
*DRAM PWM Frequency [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
i've also had a few "not rebooting" problems but it all seems fine now.
i have 6GB of G-skill F3 12800CL6T-6GBPI (not sure if it's the best combo for this mobo/cpu)
i can play and run 3dmark with these settings but it's not IBT or prime95 stable. i would also like to have HT enabled. like how the task manager looks like a piano with all the threads :p
