There is no 1T command rate in intel chipset.
My ab9-Quad gt had a choice for 1T so i think intel chipsets do have the option
Vista 32/64 bit driver for the Realtek HD codec, version 1.64:
http://www.realtek.com.tw/downloads/...&GetDown=false
Drivers also for XP and as usual...WHQL...Realtek have been really excellent in updating their drivers on a regular basis, shame it can't be said for Creative.
Tried f11. Went back to f10. F10 seemed more smooth and snappy.
Anymore comments on 1T timing for the ds3? I could have sworn in the earlier bios' there was the option, but really can't recall now after all those bios'...
I never seen a 1T option in any bios release, as least for the DQ6...one thing i did notice with the F10a beta, the Azlia codec option in bios says "Auto" and "Disabled"....i could have sworn it was Enable/Disable with F9.
FAQ updated again:
http://www.giga-byte.com.tw/Support/...me=GA-965P-DQ6
Other info on RAID etc.
http://support.intel.com/support/chi.../CS-022304.htm
http://www.giga-byte.com.tw/FileList...ich8r_raid.pdf
http://www.giga-byte.com.tw/FileList...s_work_dq6.pdf
http://www.giga-byte.com.tw/FileList...rom-update.exe
http://www.giga-byte.com.tw/FileList...river_heci.exe
http://www.giga-byte.com.tw/FileList...ablebiglba.zip
What differences would there be if I went from F7 -> F10/F11?
I'm hesitant to update my bios after F9 gave me a very bad experience. F7 has been solid for me, so would there be any benefit for me updating the bios to F10 or F11?
no i know there is 1T for 965 chipsets. i kno my quad GT has a alpha bios for1T testing. this was talked about months ago when i 1st had the mb
Possible Issues With Windows Vista* and Intel® RAID
http://forums.microsoft.com/technet/...tf=0&pageid=11
http://www.intel.com/support/chipset.../CS-025783.htm
CPU-Z 1.39.2:
http://bakkap.free.fr/Softs/cpu-z-139-2.zip
yea, i no longer have my quad gt. i m with my DQ6 rev 3.3 since my quad kicked the bucket. i knew it had 1T i just could not remember. as far as the alpha bios i think that was for my 975x AW9D-MAx i confused it with.. but yes intel chipsets do have 1T if manufacturer (965) implement them :stick:
Apparently a new beta for the DQ6 maybe coming in a week or so, i'll report back if it appears and perhaps permission will be given to Rapidshare it.
Will we be seeing any new bios for the DS4? :nono:
http://www.jzelectronic.de/jz2/index.php
Here f9b bios for ds4 (beta bios, be careful)
Thanks Masami
How do you download from that site?
Its also available at station-drivers.com... on todays files.
Don't worry I've got it.
http://www.station-drivers.com/page/...a-965p-ds4.htm
