[QUOTE=note: anybody successfully installed vista ultimate RC1 build 6000 ?? what about the clock hack, still workin..?[/QUOTE]
Grab yourself A Dell OEM version they were on NG's 2 days ago. No troubles with activation and updates
Well I got a Non-Se Rev1.03g and I'm at 3.7ghz with my Q6600, couldn't get pass 420fsb gave me a BSOD or probably not enough voltage. Ran memtest up to 2500% coverage didn't get any errors.
http://img507.imageshack.us/img507/7...me95wj7.th.png
Cool, same TJ-06 I use for one of mine. Only thing to note is that the NB wll get upto 5C hotter and bout +3 on SB in that possition. I had to remove the NB/SB pipes and use aftermakeet on one and turn on side (like HTPC style) for the other to get good temps with stock coolers on mobo. I also added a clear plastic devider to keep the origional tunneled design since we cant fit the stock SilverStone model anymore. I just trimmed and fitted it from the front fan along the top edge of the VGA (using the majority of the card as the damm) to guide air toward the rear fan. The damm came completely to top of window and folowed length of cast toward back and proved to be functional, especially on model with ThermalRight NB/SB coolers and in upright BTX configuration.
Nice case.
Ok... thks nuckin... lolol btx format case can get your temp a bit higher 1-2ºc overall, but spacewise i find it much better. all components are at hand so u wont cut your fingers... i´m sure also the nb/sb/mosfet heat tubes are opposite than they should probably, but for the average low quality of fusion block compared with others is irrelevant. anyway my avg temps are on the low side, cpu idle-35 load 62/63, nb idle-37 load-45, and sb dont even care, got a fan blowing almost straight from outside. will still give a go on watering the NB fusion when i descend from air and plunge into water lolol
btw vista really improves performance with readyboost activated, pen drive formated to ntfs (specially if you can have a voyager gt at least 4GB). for all the rest.... cant find decents arguments for it (dont really care on dx10, still a long way to go)
greets
Guys, Im having the HARDEST time OCing my Crucial Ballistix PC8500 2x1GB sticks on this board. Im on BIOS 903 and I cant sustain a POST after DDR 1016. I think I have tried EVERYTHING! Can someone shead some light on me please?
Tried different slots perhaps? white to blue or blue to white?
I'm gussin you must be on a devider for the speed you are asking for. So first off, the mobo NB and FSBT need some overvolting to keep up with the BUS load/stress, and of corse the RAM needs some more vdimm to keep the speed. I used 2.24 for 1152 in my 2nd profile on a 5:6 devider but NB need 1.52v and FSBT to 1.488v. That is with a dual, the quad with the same devider puts even greater load on memory with that devider so more FSBT and NB. My Q6600 on same 480x8 in 4;5 needs 1.55v on NB and 1.505v on FSBT with PLL of 1.712v and of corse CPU at 1.52v
Thr 1:1 with RAM frequency to AUTO and might as well leave strap to auto since ohte quad users are reporting no luck with any other strap then 266 with is defult for this CPU, so AUTO is just fine.
Good luck!
can i ask for a help???
what is the best bios for now for maximus formula second edition??
i want to put on the mobo a wolfdale
I'd recommend Bios 0903 for the compatibility with the newer CPUs. Some people prefer the earlier bios but 0903 is a major breakthrough in performance and overclocking, IMO.
thx my friend... :)
NP! :)
Check out the Maximus Formula "Part 2" thread too, for any queries you have!
Yes, I found this out the hard way. I must have shut off / restarted / cleared CMOS well over 100 times from trying all combinations of ram settings. Im now using the 400strap with my PC8500 ram operating @ DDR1130 with transaction booster enabled to "1" no way could I get this speed using the 266 strap, none the less with enabling transaction booster:up: My latency with timings at 5/5/5/8 is 49ns
49ns???
In Everest?
Something must be wrong on yours or mine since I have the exact same settings, and it's 53ns on mine in Everest and around 9600MB/s read throughput.
I'll check it again when I get home but you got me thinking, 4ns is a big difference.
So 5-5-5-8 and the rest is on AUTO yes? 2 DIMM's or 4 DIMM's? The latter shouldn't make a difference though except for the required VDIMM.
Is it normal that my maximus formula with latest BIOS(0903) can't measure core temp on QX9770? I used VapoLS but in bios I saw only +28\29 and +100=>reboot. +doesn't want to pass post check (sometimes) with high voltages (>~1.58v) due to wrong temperature monitoring.
0903. This is by far the most stable BIOS to date.
You might want to check your settings. I am getting what you see in the screenshot with 4x1GB sticks at DDR2 1215 5-5-5-15.
http://www.cyberimpressions.net/imag...erestBench.jpg
As a note, I am not running Trans booster.
DRAM Static Read - Enabled
Clock Twister - Strong
Trans Booster - Disabled
Relax - 0
yep I can confirm Renegades findings, for me I prefer Static read control enabled over transaction booster quick comparison at 9 x 333FSB with Q6600 :
First column Static disabled, TB enabled to 1, second column SRC enabled ; TB disabled relax level 0
Read 7964 --- 7954
Write 6098 --- 6095
Copy 6672 --- 6727
Latency 65.2 --- 60.5
I dunno how this works out for high FSB clocks, but we already saw some of this behaviour with P35 chipset on Asus boards... give it a shot NEWLS1 and keep us posted...
Tried that and got worse scores. sdumper and I have been through 100's of settings with this board. Our conclusion was Trans boost is to be off with relax set to 0 or 1. Static read on and Clock twister to strong if your RAM can take it. This yields the highest 3dmark06 scores, everest bench scores, and fastest Pi times.
