Originally Posted by
Deusfaux
seagate 7200.10 on SATA 1
2x Raptors in RAID 0 on SATA 3 and 4, (BOOT DRIVE)
HAD LG optical on PRI-IDE
removed IDE LG optical, installed
LG optical SATA
for now its on EZ RAID SATA 1. I can't get it detected. Ditto if I put the single Seagate in there instead.
As soon as the optical is NOT plugged in (either into SATA 1 on ICH7R or NOTHING) it works fine, and I can open it's drive bay. Seagate works on SATA 1 as well.
Neither work whatsoever in EZ RAID 1.
I have read posts on ASUS forums suggesting one CAN get single drives and devices to work on the "missing" SATA 2 port from the ICH7R controller which is what the EZ RAID ports are... via the Silicon Image controller they are the missing SATA 2 split into 2 more ports.
Apparently by removing both EZ RAID jumpers, and plugging the device into EZ RAID 1, you can use it as normally. EZ RAID 2 get disabled by default. This arrangement I guess bypasses or disables the SI controller and throws control back to the ICH7R
HOWEVER, for some stupid reason I just cannot get it to work.
Unless people have other suggestions for me, I might just have to assume its a DOA port and have to RMA the whole damn thing (over one little damn bit!)
I think it is very bizarre for the port to kill the optical drive ONLY when it gets plugged into it... not even being able ot open the drive bay hmmm
