Doesnt really matter, and 0551 is an 0551.
Doesnt really matter???? a VPMW its the same as UPMW ??
pretty much, its just apacking code. Same silicon.
ha , OK .
so it seams that i have a bit luky with mine no ???
yes, it would seem so.
is it worth spending 380 on a opteron 165 0610 stepping? and hitting 3000mhz on air?
i'm currently using a 170 0546 at 2750mhz. 1.5v at 48C dual prime
www.flickerdown.com
Brand New CCBBEs for $360
how long is the wait time?Quote:
Originally Posted by CompGeek
My CCBWE 0543TPMW is "blacklisted"...
This CPU hit the 2800 easly @1.55 (air cooling - XP90c + noiseblocker 92mm) and 2700 rock solid 1.48 :P
http://service.futuremark.com/compare?2k1=8906837
http://commanderhp.planetaclix.pt/29s.jpg
(mens is the GS kill HZ 2x 1024 mb)
Destroyer, o meu 3800 está a fazer 2850 com 1.525 e faz 2900 com um pouco mais a ar. Vou por WC, por isso preciso do maze4...
Estou esperançado que faça os 3 gigas!
MONKSp o x2 3800 so tem 1Mb cahe é diferente , 2800Mhz num opteron dual core ( 2mb cache) ekivale a 2900Mhz ou 2950mhz num x2 3800.
Um x2 3800 tem k overclokar mais para compensar o cache .
sory guys for talking portuguese , i was just answer to a friend mine :D
cumprimentos
Anything that doesnt seem to do higher than 2.8 is blacklisted. The chips that often hit 3.0 are reccommended and the ones that do 2.9 are honorable mention.Quote:
Originally Posted by destr0yer
are you sur ethe above is in english? looks liek it was in broken english. haha but i get what you mean. just kidding don't take it too serious. to bad i don't understand portugueseQuote:
Originally Posted by mascaras
yep , my english is bad too , but just typing , cause talking is not that bad :D
i was talking to my friend telling that 2700Mhz in a x2 3800 its not same 2700Mhz in a opty dual core cause x2 3800 only have 1Mb cache and opteron dual core have 2mb cache .
But I bet that I will reach 3Ghz next week when I set up my WC system. ;)
Originally Posted by MonkSP
mai nada :D
rule of thumb is .1v = 100mhz, that would put you @ 2900/1.55v, which is as high as id go 24/7
it doesn't mean that 3ghz will be hit with wC. wc is only for temps not necessarily for ocQuote:
btw, what is the top temp for opty in the safe range? 50C or 55C
55C is *technically* safe, but for optimal OC results you gotta keep it under 45C
anyone use clockgen with dfi boards? where can i downlaod the one for a DFI lanparty board nf4??
I just 3 gigas suicide shot for my old x2 3800+ and 2850 benchable :DQuote:
/mode portuguese
O mase 4 está a tua espera:D
/mode portuguese
No, they actually do matter. They don't have a coldbug. ;) A friend of mine had one that took cold very well, and clocked very nicely.Quote:
Hehe, my 170 in sig is now up for sale in FS.:)
i have a deal for a 0610 opteron 165 for 344 total? good deal?
