i dont think they can just make a ratio, if its not in intel spec i dont know how they can do that
Anvil i have that ram definitely no issues on my side
Yes I have a soundblaster X-fi PCI.
How do you know its related to the PCI Card for sure? Because people on the asus forums were having cold boot problems until a beta bios came out....
BTW I did notice something.
If I set all auto voltages, the computer does not shut down after a reboot from windows (I only saw a shutdown after saving bios settings, when I went from 5 ghz to 4 ghz and turned off CPU PLL overvolt). but if I set manual voltages, the computer often powers down after attempting to reboot from windows.
I read the guide and tried all auto voltages, and all autovoltages seem (for now) to stop warm boot problems (rebooting) most of the time.
I also don't have "cold boot" problems with the all auto voltages, (had to power off with the powerbutton due to windows 7 blue screening while trying to initialize something on the desktop) but i did NOT test a complete power off (unplugging the PSU) yet.
Clunk mentions some Asus boards have it & I have seen Coolaler run CL9 2400 with a 99.8BCLK...... I'm sure its doable just GB might not be happy to roll it out if its sketchy. Worth an ask though.
http://www.clunk.org.uk/forums/overc...ginners-2.html
http://forum.coolaler.com/showthread.php?t=252282
ASRock Beta version BIOS added nice function.."Add screen capture function in BIOS setup. Press F12 to capture."
Dino notice this to Taiwan guys.
http://img404.imageshack.us/img404/7...0124214825.png
They have to implement UEFI first then add that function :) 2400 mem speed would be nice,so far only asus on maximus 4 extreme has it,but at the price of performance,for example in 3dmark2001 maximus 4 extreme scores about 5-6K lower compare to a Gigabyte board ;)
LLC = standard , amazing vdrop IDLE 1.42 load 1.36 vcore set in bios 1.48v !!!!
100.3mhz Bclock
strapp 2133 = cold boot but when windows started = rock solid
batch i7 2600K L042B074
P67a-UD5 F6d main bios and backup
http://free0.hiboox.com/images/0311/...04b4a5ef28.png
oops 2nd post
I am having issues with the vcore stability as well now more evident further up the MHz scale, I think your auto setting has set standard, maybe try level 1 although that will overshoot by as much as std droops.
I think GB are doing something with the loadlines atm but it wants/should run something more like this std = droop whatever it is even up to 0.5 level 1 tiny bit of droop .02/3 tops but none would be nice like my DFI X58 level 2 maybe .02/3 overvolt.
Thats what i was happy about. As soon as you manage to get to windows with the settings, its stable and fast but when i wanted 24/7 rig - cold boot starts to annoy you after a few times. So every time i start up the machine i just pump the DELETE key so i can go in bios SAVE & Exit and than i begin using the computer. lol
It seems the 2400MHz multi on the P8P67 Deluxe isn't functional yet, at least not with the majority of mainstream CPUs, from what I can gather, it's for cherry picked CPUs that will run it, but most can't, and Asus say that we will have to wait for improved CPUs from Intel for this to work. Seems odd to leave it in there if that's the case.
It's certainly not working on mine, just a BSON. :rofl:
Just found if i leave everything on AUTO in the memory section, machine fires up properly w/o any problems at 4.9 ghz. But sucks to have 1333mhz CL9 as a default. If i change anything in the memory section manually the mobo says FAILED clock. What a joke...
Turbo it has to be a combo of your ram and CPU or something else because ive got testing done and only 21.33 showed some CB related issues nothing else
i am yet to see anyone post anything stable with that ratio they have, sounds like a rubber duck that option to me
I'm pretty sure its memory incompatibility. I hope G.Skill sends them some memories to try out and adjust the BIOS. I tried both slots 2/4 and 1/3, same thing. I cant even set the memory manually to 1300 CL9, failed clock. But when i set it to auto it starts up 1333 CL9 no problem. lol
ps; I want to stress that this behavior only happens when the machine is COLD BOOTED, when its been sitting shut down for a few minutes. After it boots up and when i go in bios i can adjust the memory and it is working flawlessly at 2133mhz 7-10-7-27 1T + 4.9 ghz CPU but only until i shut it down and after that i would need to go in bios and adjust it again...
do you have any idea about this phenomen :
LLC standart vcore set in bios 1.48 / IDLE 1.42 / LOAD 1.36
Linx stable at 5GHZ
LLC Level 1 Vcore set in bios 1.375 / IDLE 1.392 / LOAD 1.416
Linx stable at 5GHZ
LLC Level 1 Vcore set in bios 1.370v NO BOOT
i think that my CPU can do 5GHZ solid a 1.36V ( due to LOAD in LLC on standard ) but why the MB cannot boot if LLC is set on LVL 1 ?
i don't understand
Have you re tested 1.36v, my 2600 ran 1.33 bios on its first run then needed 1.35 for its second & so on. The chips burn in especially after weeks of LinX at crazy clocks pounding the nutz off them not to mention the damage SP1 & AVX do!!!
If you are sure your chip can still do 5GHz 1.36 than ye you are seeing something similar to me. I can no longer run std @ 5GHz it needs over 1.55v bios so I gave up. I can start high from bios & ET the voltage down but this has little or no effect at 5GHz or 5.1 it only works for me at 5.2. I'm no bios engineer so shouldn't diss those in such a position but the v drop & droop on this board combined with the level 1 overshoot & failure of level 2 are quite poor imo & unlike anything I have ever seen before.
That said you got to remember this is a new platform & we are running 5GHz here :shocked: that's flippin awesome. The only reason I am bent about the UD5 voltages is coz I want to go faster & I know the UD5 can do it.....
Yup. I would have to agree with your findings as I see the very same things going on here, we are doing the field R&D on this infant ud5.
I've tried another set of Corsairs, XMS 2000, with the same result, using bios F3 up through F6d.
First cold boot having upgraded the bios is OK but as soon as I Save and Exit with only a few changes (RAID, disable 1394, eSATA AHCI) it acts up.
It seemed like it was more willing to cold boot using IDE mode but I won't be using that option :)
The only thing I haven't tried changing is the PSU, Keyboard and the GPU.
I'll try the cpu/memory on a different MB, just to rule out some of the variables.
BTW, why aren't 3Gb/s SSDs recognized by the Intel 6Gb/s ports?
I've tried Intel G1s and they wont show up. (the C300s do work :))
SO are going to see a new bios or its the same interface?
taken from this link : http://gigabytedaily.blogspot.com/20...echnology.html
All GIGABYTE P67 and H67 chipset motherboards produced today ship with GIGABYTE’s Hybrid EFI Technology, and we have started porting this new BIOS to other chipset platforms with the intention to make it available on every currently shipping GIGABYTE motherboard. You’ll see the statement below start to appear on various online forums around the web as we start to promote this unique new GIGABYTE feature.
DualBIOS™ 3TB+ HDD Support (Hybrid EFI Technology)
3TB+ HDD support is an essential new feature for 2011 and has been one of the most talked about technologies accompanying the launch of the new Socket 1155 6 series motherboards. GIGABYTE not only supports booting from 3TB+ HDDs on all new P67 and H67 chipset motherboards, we offer the ability to boot from 3TB+ HDDs on all currently shipping GIGABYTE motherboard models (from high-end X58 chipset models down to the entry level new G41 chipset models) through GIGABYTE’s unique Hybrid EFI Technology. Hybrid EFI Technology combines the benefits of GIGABYTE’s mature BIOS platform including stability and compatibility with 3rd party products with 3TB+ HDD support from EFI technology, allowing GIGABYTE to offer the best of both worlds through a quick and easy BIOS update using GIGABYTE’s @BIOS utility that is freely available from the GIGABYTE website.
Tech companies love a good Q&A because we tell ourselves that people are interested in our new tech and are asking these pertinent questions of it. So here is our GIGABYTE Hybrid EFI Technology Q&A:
Question 1: When will GIGABYTE introduce an EFI compatible BIOS for their motherboards?
Answer 1: GIGABYTE has already introduced Hybrid EFI Technology that is fully compliant with EFI aware operating systems. This BIOS is shipping now with all GIGABYTE P67 and H67 chipset motherboards, and we have started introducing this BIOS on motherboards using other chipsets with the intention of making is available on all GIGABYTE motherboards.
Question 2: Why did GIGABYTE choose to use a hybrid EFI instead of a standard EFI technology?
Answer 2: GIGABYTE Hybrid EFI Technology allows us to quickly offer EFI functionality to a whole range of motherboards, not just the latest 6 series products, because it is based on GIGABYTE’s tried and tested BIOS.
Question 3: Why does GIGABYTE’s Hybrid EFI Technology not support using a mouse or have a mouse-friendly graphical interface?
Answer 3: Mouse support and the accompanying graphical interface are not part of the EFI spec. That’s why some motherboard makers have chosen to have mouse support with their EFI BIOS while others don’t. One of the features of the EFI BIOS is that it is modular, so mouse support and a graphical interface are additional modules that some vendors have added to their EFI BIOS. This also explains how GIGABYTE has been able to add an EFI module to our stable and reliable BIOS. GIGABYTE’s Hybrid EFI technology keeps the same familiar interface that millions of users are used to. It is quick, easy to use and overclockers can enter the BIOS and change settings as quickly (or even quicker) than if they were using a mouse.
Question 4: What are the advantages of GIGABYTE’s Hybrid EFI Technology?
Answer 4:
1. It supports booting from 2.2TB+ HDDs. GIGABYTE mentions 3TB+ because the next size up from a 2TB HDD is actually 3TB, not 2.2TB. GIGABYTE Hybrid EFI Technology provides headroom for a maximum disk and partition size of 9.4ZB (9.4 x 1021 bytes; kB, MB, GB, TB, PB, EB, ZB, YB, etc...)
2. It uses a reliable, tried and tested GIGABYTE Award BIOS that has been updated and improved over many years. Our BIOS is compatible with thousands of ICs, components and 3rd party products – a new BIOS needs a lot of compatibility testing before it is as mature as our Award BIOS. So basically we have the Best of Both Worlds with our Hybrid EFI Technology: stability of a mature BIOS and the 2.2TB+ support of an EFI BIOS.
3. Because of its design, it is easier to be backwards compatible with older motherboard models –X58 chipset down to new G41 chipset models will be able to enjoy Hybrid EFI Technology. So we are protecting our customers buying decision and helping to future proof their purchase. No other EFI solution can offer this!
4. GIGABYTE Hybrid EFI Technology is fully compliant with both EFI aware and non EFI aware operating systems.
sorry for my beginner question :)
but in fact it starts at 1.35 and 1.36v
so i'm going to test stability at 1.35V LLC 1 now
this chip is not so bad :D
EDIT : STrap 1866 or 2133 give cold boot for me
http://img256.imageshack.us/img256/5548/linx5ghz139.png
Uploaded with ImageShack.us
Looks very good my friend :up:
When you get the cold boot look at what the board has re-set back to default.... sometimes ram speed, sometimes cpu multi & sometimes it looks like nothing which I would say is a voltage issue. I only get cold boot problems when something is wrong....
Edit.... you might want to install SP1 if you are using W7, Otherwise your low vcore testing will have to be done again when you do install SP1
do you have a link to DL SP1 please ?
There are many but I used this one
http://www.ngohq.com/news/19212-wind...k-1-final.html
