hauahauhauh, funny, how much voltage are using now for 1700 7-7-7-20?
* CPU Model: AMD Phenom II X6 1055T
* CPU Stepping: 1023FPWM
* CPU Frequency: 4.06GHz
* CPU vCore: 1.440
* CPU Multiplier: 13.5x
* CPU Turbo: Disabled
* CPU NB Speed: 3010MHz
* HT Ref Speed: 301 MHz
* RAM Speed: DDR3-1600
* RAM Timings: 8-8-8-24-1T
* RAM Configuration: 4 GB (2 x 2 GB)
* RAM vDIMM: 1.65V
* Motherboard: ASUS M4A89GTD Pro/USB3
* Chipset/Socket: AM3, 890GX+SB850
* Cooling:Thermolab Baram
* Temps: 45C Idle / 65C Load, temp=33C
* Operating System: Windows 7
* 32/64-Bit: 32
* Stable/Suicide/Untested: Prime95 Blend 8h
#update#
CPU Model: AMD Phenom II X6 1090T BE
CPU Stepping: CCBBE CB 1018CPMW
CPU Frequency: 4118 MHz
CPU vCore: 1.408V
CPU Multiplier: 20,5x
CPU Turbo: Disabled
CPU NB Speed: 3013 MHz
HT Ref Speed: 201 MHz
RAM Speed: DDR3-1607
RAM Timings: 7-7-7-21-1T
RAM vDIMM: 1.52V
Motherboard: Gigabyte GA 890FXA UD7
Chipset/Socket: AM3, 890FX + SB850
Cooling: Liquid, XSPC Rasa
Temps: 21C Idle / 39C Load
32/64-Bit: 64
Stable/Suicide/Untested: Stable@LinX
nice charts, quality thread:up:
Charts updated. Talk about a busy couple of weeks. Thanks for the kind words, Monkeywoman.
@Recent Submissions: I need proof of stability (screenshot). It's not that I don't trust the people around here, but when there is proof the chart is a lot more meaningful. Until then you'll be marked as "untested".
your spot was taken on air......I just never had him update it ;)
http://www.xtremesystems.org/forums/...&postcount=369
Them thar's some tough words. Let's see it happen, Cap'n!
P.S. Lest you misunderstand where I'm coming from, I mean all of this in the spirit of friendly back and forth. I'm no hard core overclocker, but I did mill some "cold gear" for entertainment. Let's have some fun. :)
@Chew: If you want to put it in official form I'd be happy to post it for you.
good clocks is that XP though? and mines a huge 9mhz faster than i got on air :rotf:
don't worry i was just being friendly back we had a whole competition on TPU to see who could get the best clocks ;) let me get the whole marriage thing done and i will knock off what you got i am waiting on the CH4 extreme anyway ;)
http://forums.techpowerup.com/showthread.php?t=122076
comp is out of date but was still fun
ah well thats no fun i want to see some 7/vista 64b numbers out of you :)
i could boot close to your speeds on XP 32bit instead of 7 64bit same thing happened in my little competition on TPU 32bit showed better clocking and to even the playing field it was vista/7 64bit only. so either i was doing something wrong or 64bit was hindering something....
i ran 32m at these ram speeds and tried with looser timings and lower volt GSkill ripjaws...will try it out again when i get my new chip sold the setup for other reasons....on s754 again and that bugger doesn't want to break 240mhz htt :mad:
sorry if i sounded rude hydrocodone and broken wrist are kicking my ass right now
Got a few good runs over this weekend.
Suicide run of 4.6ghz @ 1.55v (1.6v real) managed cpu-z but cannot get much further. As soon as vantage starts to run it just blue screens.
4.56ghz manages a vantage run and does most other things but i do not think it's stable.
4.08 @ 1.39v stable for 24/7 operation, does 2 hour linpack tests which is good enough for me.
3.2 @ 1.275
2.4 @ 1.175
1.68 @ 0.9v
880mhz @ .8v
these seem semi stable, generally foudn that if they don't fault after 15 mins of linpack they are fairly stable.
On the hwmonitor power level @ 880mhz it's drawing 31w @ 3.2 it's 115w, and @ 4.08 it's capped at 129.08w.
Dunno if these are real or what, but they seem pretty low at the higher end... *shrugs*
Managed a cpu score of 22k with 4.5ghz in vantage.
CPU-NB speed is 2880 @ 1.25v will put some screenshots up later with some more benchmarks if people request em.
ok, today later or tomorow il get testing my second Thuban 1015EPMW...hope 4700 MHz as minimal
CPU Stepping: n/a
CPU Frequency: 3400 MHz
CPU vCore: 1.165V
CPU Multiplier: 14x
CPU Turbo: Disabled
CPU NB Speed: 1950 MHz
HT Ref Speed: 243 MHz
RAM Speed: DDR3-1300
RAM Timings: 9-9-9-24-1T
RAM vDIMM: 1.5V
Motherboard: ASUS M4A87TD EVO
Chipset/Socket: AM3, 870 + SB850
Cooling: Air (Scythe Big Shuriken)
32/64-Bit: 64
http://www.imagebanana.com/img/457nm...b/Untitled.png
That's less than two hours, wombat.
what is up with those temps wombat?? 65c for 1.16vcore??? something seems off
yes, i had more but back then i didnt make a screen. i can try to run it over night again.
@crazydiamond: look at my cooler. its made for small cases and not for oc. with more than 1.3v i have 80C+ after 2 mins and have to abort.
its not about thats its an air cooler, but WHAT kind of air cooler. with a mugen 2 ill get it to 40C@load too. and maybe i should have used some better thermal grease.
http://www.planet3dnow.de/vbulletin/...#content_start
ok, now its 8h & i can go to bed :)
x6@3.4ghz@1.165v
http://www.imagebanana.com/img/q86rl...34ghz1165v.png
my second chip
CPU Stepping: 1015 EPMW
CPU Frequency: 4080 MHz
CPU vCore: 1.52V
CPU Multiplier: 20x
CPU Turbo: Disabled
CPU NB Speed: 2652 MHz
HT Ref Speed: 204 MHz
RAM Speed: DDR3-1600+
RAM vDIMM: 1.6V
Motherboard: Gigabyte GA890FXA-UD5
Cooling: Air Box :-)
Temps: 68C Load
Operating System: Windows XP 32bit
Stable/Suicide/Untested: Stable LINX
for comparsion my first chip:
CPU Model: AMD Phenom II X6 1090T BE at 4300 MHz stable 1015DPMW with about 1.47V!!
