Been playing with y-cruncher for a bit to stress test. Nice to spot memory errors when messing with timings.
Using an AMD 940 @3.5ghz 14x250mhz, 8gb ram. For the advanced swap runs was using 4 completely different drives, just what I had around. 150 WD VelociRaptor , 34 GB WD Raptor, 1TB WD, 500GB WD. Wound up giving me a bit over 200MB/s read/writing.
Code:Validation Version: 1.1
Program: y-cruncher - Gamma to the eXtReMe!!! ( www.numberworld.org )
Copyright 2008-2010 Alexander J. Yee ( a-yee@northwestern.edu )
User: CRFX
Processor(s): AMD Phenom(tm) II X4 940 Processor
Logical Cores: 4
Physical Memory: 8,588,873,728 bytes ( 8.00 GB )
CPU Frequency: 3,499,968,327 Hz
Program Version: 0.5.3 Build 9134b (fix 2) (x64 SSE3 - Windows ~ Kasumi)
Constant: Pi
Algorithm: Chudnovsky Formula
Decimal Digits: 10,000,000,000
Hexadecimal Digits: 8,304,820,238
Threading Mode: 4 threads
Computation Mode: Advanced Swap
Swap Disks: 4
Working Memory: 7.03 GB
Start Time: Sun May 30 03:45:01 2010
End Time: Sun May 30 09:25:45 2010
Computation Time: 19,213.444 seconds
Total Time: 20,444.781 seconds
CPU Utilization: 212.99 %
Multi-core Efficiency: 53.24 %
Last Digits:
9763261541 1423749758 2083180752 2573977719 9605119144 : 9,999,999,950
9403994581 8580686529 2375008092 3106244131 4758821220 : 10,000,000,000
Timer Sanity Check: Passed
Frequency Sanity Check: Passed
ECC Recovered Errors: 0
Checksum: afbb8decc6372e5e02c4830fe70bf4be45f24dca0e6d814b1dcb7831b80f25a7
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,971,970 Hz
Constant: Pi
Decimal Digits: 5,000,000,000
Hexadecimal Digits: 4,152,410,119
Swap Disks: 4
Working Memory: 6.89 GB
Start Time: Tue Jan 06 00:46:02 2009
End Time: Tue Jan 06 03:21:46 2009
Computation Time: 8,656.553 seconds
Total Time: 9,344.830 seconds
CPU Utilization: 207.96 %
Multi-core Efficiency: 51.99 %
Last Digits:
4384678622 1397184596 0181195416 0748430457 5386741865 : 4,999,999,950
0914971996 1298184401 9216126684 9425834935 5440797257 : 5,000,000,000
Checksum: 3e90e3bd4bda69b81b6bba5e8607b4645e3e4d386de0e1e70209677b8adeadb1
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,964,882 Hz
Constant: Pi
Decimal Digits: 2,500,000,000
Hexadecimal Digits: 2,076,205,060
Computation Mode: Basic Swap
Swap Disks: 1
Working Memory: 5.09 GB
Start Time: Sun May 30 13:51:33 2010
End Time: Sun May 30 14:46:07 2010
Computation Time: 3,064.283 seconds
Total Time: 3,274.682 seconds
CPU Utilization: 252.08 %
Multi-core Efficiency: 63.02 %
Last Digits:
0917027898 3554136437 7123165188 3528593128 0032489094 : 2,499,999,950
9228502005 4677489552 2459688725 5242233502 7255998083 : 2,500,000,000
Checksum: 6d96b2b94cefff2e1c5d4262bea9ea1781508808f286eb8e16b268f48db790d0
User: CRFX
Logical Cores: 4
CPU Frequency: 3,500,033,606 Hz
Constant: Pi
Decimal Digits: 1,000,000,000
Hexadecimal Digits: Disabled
Computation Mode: Ram Only
Swap Disks: 0
Working Memory: 4.75 GB
Start Time: Mon Jan 05 22:48:11 2009
End Time: Mon Jan 05 23:00:23 2009
Computation Time: 698.078 seconds
Total Time: 732.356 seconds
CPU Utilization: 388.09 %
Multi-core Efficiency: 97.02 %
Last Digits:
6434543524 2766553567 4357021939 6394581990 5483278746 : 999,999,950
7139868209 3196353628 2046127557 1517139511 5275045519 : 1,000,000,000
Checksum: 8aa91c4c41b343c601786c9d3e1daff73d41adcccde3af4e112263b548cf620a
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,962,659 Hz
Constant: Pi
Decimal Digits: 500,000,000
Swap Disks: 0
Working Memory: 2.42 GB
Start Time: Mon Jan 05 23:03:11 2009
End Time: Mon Jan 05 23:08:44 2009
Computation Time: 315.981 seconds
Total Time: 333.237 seconds
CPU Utilization: 379.80 %
Multi-core Efficiency: 94.95 %
Last Digits:
3896531789 0364496761 5664275325 5483742003 7847987772 : 499,999,950
5002477883 0364214864 5906800532 7052368734 3293261427 : 500,000,000
Checksum: ce7f605a99f54b62064bd9e20452d0334d80ff539a58a59b1623b0a7eeb2b6cd
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,970,806 Hz
Constant: Pi
Decimal Digits: 250,000,000
Swap Disks: 0
Working Memory: 1.25 GB
Start Time: Mon Jan 05 23:11:59 2009
End Time: Mon Jan 05 23:14:27 2009
Computation Time: 138.842 seconds
Total Time: 147.274 seconds
CPU Utilization: 386.50 %
Multi-core Efficiency: 96.62 %
Last Digits:
3673748634 2742427296 0219667627 3141599893 4569474921 : 249,999,950
9958866734 1705167068 8515785208 0067520395 3452027780 : 250,000,000
Checksum: c67582ba838a1805035d66a9aa0012a5b229242cc2f0142706ce4ca19982209a
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,962,238 Hz
Constant: Pi
Decimal Digits: 100,000,000
Swap Disks: 0
Working Memory: 536 MB
Start Time: Mon Jan 05 23:27:29 2009
End Time: Mon Jan 05 23:28:21 2009
Computation Time: 48.551 seconds
Total Time: 52.071 seconds
CPU Utilization: 379.88 %
Multi-core Efficiency: 94.97 %
Last Digits:
9948682556 3967530560 3352869667 7734610718 4471868529 : 99,999,950
7572203175 2074898161 1683139375 1497058112 0187751592 : 100,000,000
Checksum: 6aadf6c6c06bcd62113787fa59d8a1a9a24150dd43ca557d1677b4b4ff6a46b1
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,961,443 Hz
Constant: Pi
Decimal Digits: 50,000,000
Swap Disks: 0
Working Memory: 317 MB
Start Time: Mon Jan 05 23:30:54 2009
End Time: Mon Jan 05 23:31:18 2009
Computation Time: 21.789 seconds
Total Time: 23.675 seconds
CPU Utilization: 378.19 %
Multi-core Efficiency: 94.54 %
Last Digits:
4127897300 0153683630 8346732220 0943329365 1632962502 : 49,999,950
5130045796 0464561703 2424263071 4554183801 7945652654 : 50,000,000
Checksum: 99b5ff37390549200f27bb917a4efa88987414e8cf0d2545112712f971118986
User: CRFX
Logical Cores: 4
CPU Frequency: 3,499,974,798 Hz
Constant: Pi
Decimal Digits: 25,000,000
Swap Disks: 0
Working Memory: 207 MB
Start Time: Mon Jan 05 23:30:00 2009
End Time: Mon Jan 05 23:30:11 2009
Computation Time: 9.945 seconds
Total Time: 11.036 seconds
CPU Utilization: 368.58 %
Multi-core Efficiency: 92.14 %
Last Digits:
3803750790 9491563108 2381689226 7224175329 0045253446 : 24,999,950
0786411592 4597806944 2455112852 2554677483 6191884322 : 25,000,000
Checksum: 9a4bb1bb0b6858fa01b70a9a0ba412b09c8f9011565814aa1db8631060a5e5c7
