No second board. :(
By BE I meant X2 BE-2300 that I mentioned earlier. Sorry if you thought it was the Phenom. :p: :D
The Phenom 9600 BE I'll have tomorrow morning.
No second board. :(
Reading off that German MSI site I gather that this new Bios has the TLB temp fix. Choking the system a bit... 15%:shocked:
I have a Phenom 9500 running with Bios 1.1 which I believe does not have the TLB fix. Correct???
The system run flawlessly on stock settings. Never a crash. That's running Crysis, Call Of Duty 4, Red Baron3d, Autocad, Battlefront 2, Battlefield2, Winxp64 sp2
So when will this TLB bug bite?? Besides the rough fix patch????? Only when overclocking it seems.
Or maybe some chips are worse then others??
So hopefully this bios will fix more then it may break. My problem remember is i'm STUCK at 1 stick at 1GB. So single channel and 1 tiny GB of ram :)
So dual channel at 1066mhz and 2gbs might get me back to break even or faster.
Will report back with more info
Brain
interesting. haven't compared the 2 bios's as far as performance goes. Any suggestion on an app to try?
I just installed 1.22 this morning. Dunno why, really was no reason to, it didn't do anything for me. still can't run my 1066mhz ram @1066.
Anyone know why frequency is grayed out in AOD for memory? I'm guessing the divider isn't changeable on the fly. It's set 1:1 right now. I've got the HT up to something fairly low atm. Last I checked I think my CPU is running around 2.4ghz. HT @ 218 or so. So the ram is running around 436. I know it can go faster than the HT/CPU. just wish I could up it :(
Sorry to tell you guys.
I was busy earlier but tested two Phenom 9600 "Black Edition" this morning. Both were CAAZB 0743. Never brought them home, tested them there and then to see if they were actually BE as they were unopened. I tried everything, both were not BE, they had multipliers locked at 11.5x although they were sold as BE. :(
So I just left them there and uncle will see to it instead. Quick photos with my phone are too messy to show. Saved 1 or 2 very quick screenshots and validations inside 5-10 minutes.
Stock 2.3GHz: http://valid.x86-secret.com/show_oc.php?id=288978
2.6GHz: http://valid.x86-secret.com/show_oc.php?id=288979
http://img341.imageshack.us/img341/6048/fsfsfwv2.th.jpg http://img186.imageshack.us/img186/9...fuuuey4.th.jpg http://img84.imageshack.us/img84/2298/fdfdfdab6.th.jpg
Max was 2.67GHz within the 5 mins before it froze. First one had HT wall at 213MHz and 2nd one did what you see in pics. Didn't bother with another boot.
I don't know who supplied my uncles firm with them but other suppliers may also be doing this saying they are Black Edition and that your BIOS is just not supporting them yet. This is bogus. You can check through P-States manually even if box says whatever.
Also Phenom shut down temperature is 75℃. Tried it. :D
Temps in BIOS are accurate just like digital thermistor.
Yep.
Not when oc'ing. If it ocurs it'll occur at stock. Try VMWare and you might see it. Virtualization, i.e. heavy frame-page cache entries is when you are most likely to see it IF your chip is affected.Quote:
Ignore this new BIOS. Seems to only degrade things for the worse unnecessarily.Quote:
WinRAR, POV-Ray, Cinebench 10, wPrime and so on.;)
Yep.Quote:
It'll be running 1:2 divider then. ;)Quote:
I'm linking BIOSes P0C, 112 & 113 below. 113 is best so far according to my experience without the TLB errata fix.
http://www.yourfilehost.com/media.ph...le=MS_7376.zip
I have a noobish type question for you folks...
I just built a new K9A2/9600 system and I didn't bother to install a floppy drive in the machine....
My question is... Can I boot into safe/command prompt mode and flash the bios from a USB jump drive, or just flash it from a DOS prompt inside windows?
So
I have two systems
Both MSI K9A2 Platinum
One has a Black Edition 5000 X2
The other has a Phenom 9500
They both are running the same Cosair ram TWIN2x2048-8500CD G.
Both machines could not run with 2 stick of ram. Wouldnt even post. With the bios update the Black Edition 5000 x2 could see the other stick. The phenom system could not.
So I have the 1.22 the phenom now and can not get these ram sticks to work. Tried increasing voltage and what not. Nothing. The black edition x2 will run them no problem.
Ok as for the No Floppy Drive.....
I ran in to that problem. You need to make a boot cd.
I used Hiren's BootCD 9.3. I could not get my cd-rom to work with it.
But I did get my USB thumb to work. So I selected USB support with Himem. Then select 1 for mass storage. Also old system which is USB 1.1 was how my USB stick got detected. It will then assign your thumb the C: prompt. So just stick the files on the thumb.
Probably a better way. But this junky/clunky system wouldnt work any other way for me.
Good Luck
One stick of ram and now a useless TLB fix on my phenom. Gonna shoot the board. Maybe RMA... Or take the time to put a x2 in to this board and see if the ram works with that.
Gotta have 2gbs to play games now days.
That is not good news. How will we know if they are BE's or not when we order them .At least you were in the position to check them first .KTE were these part numbers indicated on these:
OEM Tray = HD960ZWCJ4BGD /
PIB = HD960ZWCGDBOX
Try it, usually it works. You can use MSI Live Update 3 and you can get v1.1 flashed within Windows without anything other if that fails. I use a FDD always, never tried the USB method with this board. Too much of a headache and FDD method is very easy.
I am sure I've read somwhere by MSI that you need to first get into DOS environment by having the few necessary files on the USB/CD. Then type the relevant commands to flash using the flash utility as long as USB detection is enabled and your board can see it as a drive.
More info might be on the MSI site although I couldn't find it with a quick look.
Flash v1.1 from MSI site as above. You don't need 1.22, it's literally crap. ;)
Are you placing memory in DIMM slot 1 and 2?
Are you setting voltage to 2.2V or 2.3V?
Are you choosing dividers below 1:2?
Are you changing RAM timings manually to the rated spec?
You have to do this before you know if its compatible. So far based on what you've said the Phenom compatibility is the issue and not the board since the memory controller is within Phenom. Also if your RAM is not specified as compatible (tested) the it isn't MSI's fault. I learnt that too. :(
They were retail so it should be the second. I don't recall off memory but I don't think they were those P/N. I think the 'Z' was replaced by a '0' which IIRC is the standard 9600, i.e HD9600WCGDBOX
I'll checkup again. But I now know who the distributor is and have been in touch and they still insist it's the Black Edition. :rolleyes:
Me thinks they're playing games since they had promised delivery of 30 PCS of 9600 BE by 23rd and maybe never had them so sent common 9600 instead. I've even seen the dispatch note and invoice, they state 9600 Black Edtion. :rolleyes:
That is truely a shame. I had such high hopes when you mentioned a possible Phenom BE test. Lets hope this situation can be resolved quickly.
Thanks gareth170. I've not tried USB flash on this board, some boards allow it and others have problems with USB detection in DOS environment especially new boards. :)
LOL! I did :D :D :DQuote:
Originally Posted by blargman
I'm normally rushing you see :stick:
Yep they did. But it doesn't resolve anything I've seen yet, certainly not the 1066 issues.
Yes manually. Auto normally sets VDIMM to 1.8 or 1.9V which is too low for many RAMs especially 2x2GB. ;)Quote:
Are you setting voltage to 2.2V or 2.3V? ( You do this manually? I've always set mine to auto.)
Auto will choose 1:2 divider. You can choose it manually to 1:2 or anything lower, should work fine. Higher than that usually errors unless you have JEDEC approved 1.8V 1066 RAM which is hardly anyone.Quote:
Are you choosing dividers below 1:2? (same here, auto :s )
Check your SPD/EPP info with CPU-Z under the SPD tab. That should list the values you need from CAS to tRC and tRFC. You can check the rest in AOD memeory to see what they are at bootup and play about until you find the RAM upper and lower limit. Keep testing stability though.Quote:
Are you changing RAM timings manually to the rated spec? (how would one know what these are?)
hrmm, interesting. i'll definitely play around with it when i get home....ermm, i mean the memory that is ... :D thanks KTE
**If any of ya can contact MSI then request them for a BIOS option to control CPU NB Voltage. It's doable and it's one of the main options we need.**
As for me, MSI doesn't seem to like me too much nowadays. :D
Just so you all know I managed to get the Bios flashed...:)
I found an old floppy drive with 98 on it that loaded the CD drivers, unfortunatly there wasn't enough room on the floppy, so I just burned a Cd with the flasher and the BIN file on it... Kinda cheesy I know, but Hey it worked :p:
Looks like I hit a wall for the night... 228 HT stable 2.6 Ghz, the only redeeming factor was I didn't have to bump any V's except my Mem to 2.0 which is within it's specs (2.0-2.1)....
This is more of a PITA than I had expected! Guess I thought I was special or something... :rofl:
Well here the link to the MSI Tool to update your BIOS on a MSI mobo. It works like a charm- for a USB stick/device ( the one KTE was refering to)
http://forum.msi.com.tw/index.php?topic=113295.0
That would be why the X2 Black Edition system works with the 2 rams sticks.
Because of the memory controller is in the processor.
Ugh.
Will try to enter all the specs. AGAIN. You know my ram says 2.15v But the board only does it in tenths. So I have 2.1 then 2.2.
Also. Has anybody gotten the ram at 1066mhz? With on stick I played around with the divider. I got a half post with a logo screen colors all messed up.
Right now I'm just looking for a post at any speed with two sticks
Good news my X2 Black runs two sticks with a 4-4-4-12 but 743mhz. I have not pushed it yet. I have enough computer headaches with this phenom and another intel system.
Thanks Swanie. :)
Yep, that too Mr.Q. But I doubt IMC multi is changeable on the fly. A hardware limitation me thinks.
Brains1: yep that's another thing they need to allow, finer voltage adjustements. Going up in 0.1V is a massive jump for memory and near enough any component.
No one has 1066 working on MSI/DFI/ASUS boards which is not 1066 1.8V SPD rated. Only Gigabyte boards that I've seen yet doing 1066 at 200HT ref.
Thanks EBL :D
It'll let us test the NB speeds and to see it's limits and bugs with voltage.
