.........And made them uncertain AND confused!:rolleyes:
A question, can a HD3850 work in Crossfire with an HD2600 card..and still separate adjustable clocks and so on?
...or an even older card for that matter?
My first post in this thread...but here is what I've got so far...
Q6600 G0 @ 4.0Ghz (445FSB)
2GB G.Skill DDRII @ 890Mhz 4-4-3-5
2 x Sapphire Radeon HD 3780's (stock clocks)
My CPU and both cards are liquid cooled. The cards are idling at 29C and 28C so I should have plenty of room for overclocking. The BIOS are flashed so I can surpase 860Mhz for the core. Catalyst 7.11 installed.
Starting Point - 3DMark06 - 19,796
For those of you that is not using the stocking cooling solution, how are you guys cooling the digital pwms on these things?
Has anyone tried using a Zalman VF1000 with the 3870? Im worried it might not have enough clearance to keep the stock pwm heatsink in place.
Does anyone got his 3850 512 shipped with the new bios (allowing >862MHz for core)?
If yes, any oc results?
Setup:
http://www.expreview.com/img/review/...i/platform.png
Crossfire-X:
http://www.expreview.com/img/review/...sli/cfcom1.png
http://www.expreview.com/img/review/...sli/cfcom2.png
SLI vs Crossfire:
http://www.expreview.com/img/review/...sli/cfsli1.png
http://www.expreview.com/img/review/...sli/cfsli2.png
Crossfire wins.
Cunsuption in SLI system vs crossfire system:
http://www.expreview.com/img/review/...88gtsli/pw.png
A crossfire HD 3870 system spends same as a 680i + single 8800GT.
^^Interesting indeed.
Finally a review with 2 different mbs. The results make it pretty obvious why all reviews should use this method (if they can).
This also puts into prospective the cost factor of 2 3870 vs 2 GT and the performance associated with them.
Where is my second HD3870?? :D :D
I really love the power consumption.
nice :D
does the zalman vf900 fit on the 3850 or 3870?
awesome!
Me too! :)
When I tested HD2900 CF setup set @777/980 +my X2 6000+@3500Mhz 1.5V power draw from socket was reaching 720W during 3DMark06 run!!
Now with this pair of HD3870 set @877/1311 all the rest identical I can't even push over 450W!!
That is huge improvement under load, but idle is amazing too! It's better (lower) with two cards than what it was with ONE HD2900Pro(XT) :up: !
Me getting my Sapphire HD 3870 in few days, Play.com finally shipped it to me.
Hehe I´m also monitoring power consumption with my Gigabyte Odin (yes I know, weird system, and inaccurate) but my system with the 2900XT idles at 150W, with an X800 at 100W, and with 3870 100W too! Impressive. And loaded, 2900XT 330W, 3870 only 235W!! More impressive. In a few days I will test 3870 CF.
Am I in the right place, sounds like I would be lost in XtremePowerSavingSystems.com? :confused:
Soooo, basically, in performance wise
8800GT > 3870 > 3850 > 8800Ultra > 8800GTX > 2900XT > 8800GTS
