Thanks, but it has not helped me... mother does not wish 533Мhz to hold... I haven't already force and patience. :wth:
Maybe is the processor unsuccessful or memory?
this or rampage extreme. extreme is more rare'r that runs @ 16x but this board can run sli @ only 8x... correct me if i'm wrong
M8, that has been OVER 1 month since you psoted that claim !
If you have by some miracle found some magic setting please FGS share them !
humeyboy
sorry mate, i was busy at work a lot. Will post pics on Sunday ;)
its monday where are the pics:shrug:
:horse:
You are running a dual-core on your MIIF correct? Other than memory or NB ..you should not have any 'wall' at such low fsb. I do not know any E8xxx that has fsb wall below 600mhz or at all for that matter... :shrug: ..I was running ~1.48v MCHv for 533-570mhz fsb.. so long as mem latency was kept above 50-52ns.. [using 2x1's of course].
Guys, I can`t make my board work at FSB 500:shrug:
So post your settings maybe some people still can help you to finetune?
Hi hello, you know where I can find the bios mBIOS 2302?
Hello, I need help 4.0 Ghz, so I'm getting 3.80 GHz
Processor: q9550 e0 (vid 1.25v)
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
Ratio CMOS Setting: 8.5
FSB Frequency: 450
CPU Clock Skew: Auto
NB Clock Skew: Auto
FSB Strap to North Bridge: Auto
DRAM Frequency: DDR2-1081MHz
DRAM CLK Skew on Channel A1: auto
DRAM CLK Skew on Channel A2: auto
DRAM CLK Skew on Channel B1: auto
DRAM CLK Skew on Channel B2: auto
DRAM Timing Control: Manual
1st Information:
CAS# Latency: 5 DRAM Clocks
DRAM RAS# to CAS# Delay: 5 DRAM Clocks
DRAM RAS# Precharge: 5 DRAM Clocks
DRAM RAS# Activate to Precharge: 15 DRAM Clocks
RAS# to RAS# Delay: Auto
Row Refresh Recycle Time: Auto
Write Recovery Time: Auto
Read to Precharge Time: Auto
2nd Information:
Read to Write Delay (S/D): Auto
Write to Read Delay (S): Auto
Write to Read Delay (D): Auto
Read to Read Delay (S): Auto
Read to Read Delay (D): Auto
Write to Write Delay (S): Auto
Write to Write Delay (D): Auto
3rd Information:
Write to PRE Delay: Auto
Read to PRE Delay: Auto
PRE to PRE Delay: Auto
All PRE to ACT Delay: Auto
All PRE to REF Delay: Auto
DRAM Read Training: Disabled
MEM. OC Charger: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
Common Performance Level: Auto
Pull-in of CHA PH1: Disabled
Pull-in of CHA PH2: Disabled
Pull-in of CHA PH3: Disabled
Pull-in of CHB PH1: Disabled
Pull-in of CHB PH2: Disabled
Pull-in of CHB PH3: Disabled
PCIE Frequency: 101
CPU Voltage: 1.32500
CPU PLL Voltage: 1.56625
FSB Termination Voltage: 1.35175
DRAM Voltage: 2.30350
North Bridge Voltage: 1.33850
South Bridge 1.5 Voltage: Auto
South Bridge 1.1 Voltage: Auto
CPU GTL Reference (0): 70
CPU GTL Reference (1): 70
CPU GTL Reference (2): 70
CPU GTL Reference (3): 70
NB GTL Reference: Auto
DDR2 ChA Reference Voltage: Auto
DDR2 ChB Reference Voltage: Auto
North Bridge DDR Reference: Auto
CPU Configuration:
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
my configuration:
Core 2 Quad Q9550 @4.0GHZ|Cooler CPU Corsair Hydro H70|Asus Maximus II Formula (P45)|GeIL PC 8500 8GB (4 x 2GB) DDR2 1066Mhz|1 CRUCIAL M4 CT064M4SSD2 2.5" 64GB SATA III SSD com SO|1 OCZ Vertex 2 OCZSSD2-2VTXE120G 2.5" 120GB SSD FSX|2x1TB(RAID0) WD Caviar Black(WD1002FAEX) SATA 6Gb/s 7200RPM 64MB|HighPoint RocketRAID 2710 PCI-Express 2.0 x8 SAS/SATA 6Gb/s|EVGA GeForce GTX 460 FTW 1024MB GDDR5 EE(External Exhaust)|Fonte CORSAIR Enthusiast Series TX750 V2 750W SLI/CrossFire Active Power|Gabinete Cooler Master HAF 922|LG 37LH55 37-Inch 1080p 240MHZ LCD HDTV|Windows 7 Ultimate Final 64 bits
Some of those settings at high for 450FSB, even if it was set to more stressful 1:1 Ratio!
You need to find a good NB GTL setting not leave at auto and CPU GTL's should not really be +or - 70 if you worked out the calculations!
I had issues over 425FSB till I set NB to +40, then its a brick wall at 475FSB same as most users find with a Quad and very hard to get past it unless your lucky with a good sample Mobo!
I got some 1200mhz Memory the other day to see if its really easier to do 5:6 over 1:1 and even though it runs them at 1200mhz I still cannot get any higher FSB that is 100% stable, 500FSB for me is not going to happen on a Quad only my older Dual.
Mobo lacks any real support and Bioses were crap!
with VTT 1.32500, which the values of GTL's? how to calculate
0/2 (ref. VTT x 0.635) =
1/2 (ref. VTT x 0.667) =
NB GTL (ref. VTT x 0.64) =
thank you
1st post shows GLT's in layman's terms, remember you have a 45nm CPU not 65nm.
http://forums.pureoverclock.com/show...I-Formula-Club
Hello,
according to my calculations GTLs is;
DRAM Voltage: 2.30
CPU GTL Reference (0): 30
CPU GTL Reference (1): -10
CPU GTL Reference (2): 30
CPU GTL Reference (3): -10
NB GTL Reference: ?
how to calculate the value NB GTL Reference: ?
NB is not as clearly stated anywhere!
I think I Googled links and ended up using same calc as CPU's but for whatever nm (size) the NB is (cannot remember right now but it may be 80-90nm).
I set NB GTL by testing. It varies from board to board, just have to find the sweet spot. With mine, it'd be stable in Prime/LinX and mem tests, then it'd crash out of games (crysis I think i was playing a lot at that time). By dropping the NB GTL to -30mv or so it fixed it right up. For others they needed to do for ex +30mv.......just depends.
Need some advice. I "upgraded" my VGA card from an ATI Radeon HD 4870 to a 4870x2. After the install of the new card, I cannot get the system to power on. When I turn on the PSU, the "Republic of Gammers" light, power on and reset lights on the mobo, and the CMOS reste light/button on the IO panel flash repeatedly. The BIOs LED also flashes. So , why don't I go back to the old 4870 to rule out the card? My card is water cooled, and I want to avoid disconnecting the plumbing if I can.
I have verified that it's not the PSU by hooking it to a tester. Thoughts? Is there a particular BOIs level needed to support the x2 card?
Thanks for any feedback.
***UPDATE*** - Never mind. Bad USB2 card in the PCI slot. Replaced and all is well.
Should make zero difference, its SLI/Crossfire on a stick for dual GPU cards so its seen as a single GPU until you install drivers in Windows!
