OCZ plat 2gb pc-6400
I'll keep watching as I have a DS3 with an ide cd drive on that Jmicron port, I have a couple of adapters that convert ide into sata one might work, Although one that I know the location of may not.Quote:
Originally Posted by mackintire
Originally Posted by Richard Dower
thank for the infos guys. guess a better ram is what i need haha
This mobo is working every day better.
E6300 @ 3150 450x7 || DS4 || Twinmos Twister DDR2-800 1.9V @ 900 2.05Vdimm Elpida IC
Super PI 1M
http://img480.imageshack.us/img480/6...lockta1.th.jpg
Super PI 2M
http://img186.imageshack.us/img186/1...lockaf6.th.jpg
Super PI 8MB
http://img186.imageshack.us/img186/6...lockqe5.th.jpg
Orthos few hours.
http://img186.imageshack.us/img186/6...6300tr8.th.jpg
Everything on stock voltage besides CPU (1.31V BIOS, 1.29V load), 2.05Vdimm.
The only thing i am worried is about NB temp since i cant check it but should be ok right ? 450 fsb is not too much :D .
I think it's time that I changed my mobo... I think its obvious from reading around that E6600's dont clock well with P965 chipsets and this is only causing me more grief that it is worth, so in the near future I will be purchasing a new board. This time thorough research is going into it!
Just for clarification I don't think this motherboard is bad, I think the chipset is not best suited for E6600s (aka Conroes)
the chipset is quite fine with conroes. The thing about 6600's is that if you're intending on running 3.6, 400fsb would suit you quite well. However, if you're looking for more, you'd be much better off dropping the multiplier to 8x since you don't recall internal latencies from 400 until 466. What makes you say that p965's aren't suited for conroes? They have inherent cold boot oddities, which I've also seen in older p945's. Asus says it's because of special signaling required to get the southbridge powered while running higher fsb's.
People have said that e6300/6400 were best for p965 and not i975x not because p965's aren't suited for e6600's, but because p965's generall clock into higher fsb's than 975's. That said, e6600 and 975 has been a great combo because of the fact that 6600 has a high multiplier, and 400fsb is reasonably attainable on 975s, especially newer ones. Whereas, with a lower end c2d with a lower multiplier, you'd probably be hungry for more clock speed, and you'd end up getting fsb limited by the board.
WOW mine too..Quote:
Originally Posted by ScythedBlade
Except it's said to be compatible with the D6Q not the DS3...
I'm coming back for one more shot with a rev 3.3. Hoping it holds the OC on cold boots this time...
lol a little soft spot there eh? good luck :)Quote:
Originally Posted by dnottis
Originally Posted by ziddey
I need more vdimm than 2.1v and for $116 how can you go wrong ;)
If you have a dmm and are willing to do some testing, I might be able to determine a pencil voltmod for it.
totally agree, when the board was $150, ehh. came down ALOT, def worth the $$ now. keep us posted on your results, i had bad cpu batch when testing my latest boards, not 1 cpu was worth a fck. are you using the same 6300 that you're getting 515fsb on the asus with?...Quote:
Yea, same CPU. So far its looking good. Not as good as my first DS3. Seems less vcore provided at the same settings but Im used to that with the P5B-e. Still testing oc and stability - need to shut down and check the cold boot issue too. I'll report back in a few days after I get some time with it. Right now trying to get orthos stable at 3.5 Ghz, before 1.4 would yield me 1.35v - this board at 1.4 gives me about 1.32 so I needed to bump up a touch.Quote:
Originally Posted by burn what?
Post some pics later, i have a DS3 with a E6400 and i am also testing it ...
Download Memtest86 v3.3 + ClockGen v1.0.5.3 + SpeedFan v4.32 + S&M v1.9.0a + ATITool 0.27 Here :
http://www.xtremesystems.org/forums/...25#post2044125
hey guys what do you think the chances of getting a revisions 3.3 from a etailer is now? I was gonna order from ncix up here in canada but im unsure as I really want th 3.3 revision. Its either the 3.3 gigabyte or the biostar mobo. Im not totally sold on the biostar yet and i have no idea if it supports 1333 fsb (something i want in a bit). So what do you guys think? Good chance of a 3.3 or should i go with the biostar? (does the biostar support 1333 fsb either)?
they should all be. Newegg sent me 2 x rev 3.3s this week. One an order and one an RMA for rev 1 that dies.Quote:
Originally Posted by Super strokey
It's been a while we ain't got a new BIOS to play with :(
I bet the Gigabyte 965p development is ending soon or maybe already ended!
Bleh anyway I'm going with a Bad Axe 2 as soon as it arrive. The Ds3 will do my HTPC I think.
New DQ6 Rev 2.0 review:
http://www.pcstats.com/articleview.c...id=2092&page=1
Not much happening on this thread these days?....we need a new bios update badly!
ok, guys I have a little bit of problem with my DS3 rev2, it reboots it self contentiously and it wont display anything when it stays on.
I don't know how am I going to flash a bios without any displays.
everything else is working, and do I have a dead motherboard?
CPU-Z 1.39.1
http://bakkap.free.fr/Softs/cpu-z-139-1.zip
How is the F8 Bios for Gigabyte 965p S3 with this memory:
Corsair TWIN2X1024A-5400UL 2x 512mb?
whats your mobo revison? best revison for your memory is Rev3.3Quote:
Originally Posted by jeffyjaixx
if you dont have rev3.3 :
5400UL is Micron D9 and I think you can do Max 1100Mhz with it but try Latest S3 Bios for better Overclocking of Micron D9
