SMART Not Reporting Correctly For HDs Connected to JMicron (White SATA Ports)
I have been using the F12 BIOS and recently added a few hard drives. In order to accommodate all of them, some of them were hooked to the JMicron (White SATA Ports). They all formatted fine and work like they should, but Everest shows no SMART info on them. The screen where the info should be is grey, while all HDs hooked to the blue ports report like always. There is nothing wrong with the new drives, and I also hooked up a drive from the blue port to the white one, and it stopped reporting SMART data.
I had to go as far back as the F8H BIOS, to get SMART data to report anything, and even then it was only the temp. I am now on F7, and I still only see temp.
It would be really nice to have a new BIOS like F12 that had working SMART for all SATA ports.
I am open to suggestions or help. Thanks in advance.
