P35 LT restart and rapidly ON & OFF
Everytime I try to oc my quad above 3.3 Ghz and start prime95 the systems start automatically and then it ON and OFF rapidly several times and then start again as normal.
Did anybody experience this crap symptoms before.
The systems start automatically faster followed by several rapid ON and OFF when I clock the cpu higher and then start priming.
:shrug:
I already tired to troubleshooting anymore. Already working with this problem for more than a week. Some of the troubleshooting that I have done so far.
> Tested with 2 quad Q6600. One with bad batch with high VID and one is from batch 737B441 with low VID which can clock 4 ghz easily. FSB jumper on mobo are on CPU select. The problem is still there.
> Tested with several BIOS with Tmod CD. Problem still there. Tweaking the BIOS nearly the same like on anandtech. I even relaxing all the timing. Even tried all on AUTO. Problem still there.
> Ram is OCZ SLI with d9gmh chips. Should be no problem. But havent test with memtest. I dont think it memory related because the systems restart and rapidly ON and OFF.
> Power should be enough gamestream 700 with noctua fan. Pissed off with loud fan. Did this psu have any issues with this mobo?
> I just using and old 7900gt which should not eat lot of juice from the psu and put it on middle PCIe slot with 4x. I have a clearance issues with ram slot. What a bad layout. Which human that need the third PCIe slot with 1x ?? grrr
> Cooling should be no problem. Have 2 seperate loops on the system and small 60mm delta fan on mosfet. Even put some microchip on the PLL.
Should I RMA this board. Never RMA a mobo before since NF4 days. I wish I havent sold my p5k for this digital pwm. :cussing: :cussing:
HELPPPPPPPPPPPPPPP
