I did, and in XP x86 stayed 3GB max
I ended up at 410FSB just because my Corsair refuses to be stable at even 411. The lack of headroom for OCing must not bother Corsair since they want folks to buy the even-better memory, so I'm considering this a sad lesson about spending more than I want to to get that extra value...
I just want to thank you to all ..for all your help. :toast: :toast: :banana: :banana: :D
My system is running at OC @4.0GHz
Thank you again.
I got some XMS2 here that will run perfectly @ 400 4-4-4-12 1.9v but won't run @ 450 5-5-5-15 2.2v
I'm pretty sure it's the board.
Meh I have been using bios 1804 for ages and i just flashed with 2004. Now my temps are all weird, it shows -14C for chipset and 64C for processor, when the coretemp shows 35C.
That makes my fan spin at full rotation... I can't revert back to 1804 damnit.
here is my system: PS Thermaltake 850W ( you need more power ). CPU ver B, water cooler all the NB, SB and chipset by Nautilus, water cooler CPU block Storm, water pump switech, Rad PA120.3, Rad Fan 120 @ 3. Bios 1602.
CPU freq @ 445
Perform Mode:Standard
pci express:101
PCI Clock Syn 33.33
Mem vol:2.25
CPU Vcore : 1.5
FSB Term. :1.4
MCH Chipset V1.65
ICH Chipset V :Auto
Digtal Home..: Disable
Advaced Chipset:
Dram Timing : auto
Dram ECC Disable
Hyper Path 3 Disable
Dram Throttling Enabled
All PEG Setting Auto
Advanced CPU
Micro Update: Enabled
Virtuallizatiom Tech : Enable
All else are Disabled
Device Setting
1394 Controller: Disable
PCIE GBLAN 1 or 2 Disable if you not use them
Jmicro SATA: Disable if you not use them
Serial Port Address: Disable
Final thought: The most two important are Power supply and CPU Ver B:toast: :banana: :banana: :clap: :D
I can not post my CPU Z database ( saved in Micsoft Words), if you guys know how please show me
So I can post for everybody can see. Thanks
look at the id and give us the link. we can view it online.
ID 179455 by Vincent Nguyen http://valid.x86-secret.com/show_oc.php?id=179455
ID 179464 by Thin http://valid.x86-secret.com/show_oc.php?id=179464
Hope this can help.:toast: :banana: :banana:
Yes. I do have alot of thing connect to it. two diff water cooling system, exshaut fans, 5 HD ( 250 to 300 G)
I wonder what the 4,340 posts in this thread mean..is the P5WDH is the most popular board around here or the one users have more problems with.
Any news on that utopic BIOS that allow us to change memory settings?
Corsair TWINX 2048 MB PC6400 DDR2 800MHZ:toast: :banana:Quote:
I see you are running memory at 5-6-6-18. What Corsair you have?
Of what? CPU or MEM? both of'em listed.Quote:
What voltage!?
NB, SB and chipset real cool and it will help.
Also try to use Bios1602
I updated to bios 2004 and now it won't revert back. I really wanted 1804 back.
wow! just finished all 175 pages and my new rig is stable thanks to this thread.
E6600 @400x8 3.2ghz 1.37vcore
ram 1:1 400 4-4-4-10 v2.05 gskillz pk's
all my voltages are very low since I don't run a fan on my ninja...
the feature of the board are nice...my biggest problem is heat and I bought this to run fanless I hate the fact that asus didn't cool the nb/sb well enough without aftermarket features.
anyhow thanks again and I'll post again before too long.
If you have the same XMS rev 2.1 sticks as me it probably wont clock much cos it has ProMOS chips - some will but most wont. Only early rev of XMS 6400C4 had microns - check the chip list. I unfortunately bought mine before I found this. http://ramlist.ath.cx/ddr2/ . That said they run fine at rated speed - its just the fun of overclocking them I miss!
I must be really unlucky because my XMS2 6400c4 memory has microns as the sticker on my modules says it's rev 1.1 and I can't get it to boot with FSB at 400 and manual memory timings of 4-4-4-12. Even at stock FSB speed, it doesn't work with manual memory timings of 4-4-4-12, maybe because the board has problems with the 2:3 ratio (is that correct ?)
And yes I'm setting the memory voltage to be 2.1v
Recently set up the Asus P5W and used WINTEC AMPX 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Latest bios, still the motherboard posts with the memory as single channel.
Suggestions?
Thx, Bob
