Originally Posted by
Talonman
Final Report on my FSB limit for now...
"Recap of my findings:
So far With the Maximus and my Q6600 GO:
My CPU Voltage setting of 1.46250v (BIOS), will allow error free Priming with a FSB Frequency 414 giving me 3.7GHz with my 400 NB Strap.
My CPU Voltage setting of 1.506v (BIOS), will allow error free Priming with a FSB Frequency 424 giving me 3.81GHz with my 400 NB Strap.
My CPU Voltage setting of 1.51875v (BIOS), will allow error free Priming with a FSB Frequency 428 giving me 3.85GHz with my 400 NB Strap.
My CPU Voltage setting of 1.51875v (BIOS) starting taking errors 4 minutes into prime with a FSB Frequency 432 giving me 3.8888GHz with my 400 NB Strap.
I did successfully prime 3.9GHz with a FSB Frequency 435 for 45 minutes, but stopped the test.
For my system it requires me to set in the BIOS a CPU core voltage of 1.55000v's, and Everest reads 1.53v.
You also must bump your CPU PLL to 1.60v's.
1.55 Core and only 1.56 PLL would not Prime 3.9GHz error free."
** I added in a TV tuner card 2 days befor my GPU swap, and the system was fine. No problems booting, still 3.8GHz under 907.
I took out an 8600 GT, put in a GX2, and could not boot withought getting a CPU init hang on the LCD poster, right on the initial boot after the install.
I had to back down my FSB speed to give me 3.3GHz to boot for the first time with the GX2 installed. I did fight my way back to 3.4GHz, but no more. (Still on 907)
Now I flashed to BIOS 1004, GX2 still installed, and I am back at a 3.465GHz limit. Any more FSB than 387-388'ish will result in core dumps, Vista lockups, and sometimes not posting. I threw more volts at about everything I could... Took all the posted settings, and combos I could, Enabled, Disabled, and Autoed settings for 2 days...
Made no differeance... Thanks for everybody's help BTW!! :up:
I am keeping 3.465GHz for now until some new info comes into light. Until I hear from another Q6600 Maximus SE dude, who was running at 3.8GHz or faster, and plugged in a GX2, and still heald his speed... I think it's a limit of some sort right now...
I have no explanation, but there it is... :)
If I have to run my water cooled rig at 3.4, I turned some bells and whistles back on in the BIOS that I like... :p:
I also backed down the voltages to show how easy I can run with a FSB Frequency of 385...
It's not a bad chip! It's a Maximus, Q6600, GX2 combo thing.... :shrug:
Only about 45 minutes, but my stability is there. I have had no problems so far, and don't expect to... (Still on the good side of my 390 FSB limit)
For trivia, a Q6600@3.465GHz and a stock GX2 SSC = 17,775 3DMark06 points at default settings. (Only for the 3DMark fans.. don't yell at me!) ;)
I still love my GX2, but i'm not sure the Maximus SE does?
