Originally Posted by
xEnergie
Hey guys,
Just setup a new system with current specs. When I start up Prime95 and do a blend torture test, I notice a super high pitch whine as it's testing. It sounds like a high pitch whistle that's not consistent, but with a high enough frequency that it does sound consistent. Kind of hard to explain but think of it like this. When I say consistent I mean it as a "diiiiiiiiiiiiiiiiiiiiiiiii" sound. The sound I'm getting is a "di-di-di-di-di..." with a really high frequency so it does sound like "diiiiiiiii." Ok, I'll stop now before I confuse myself and you guys even more.
When idle, it does not make any noise. I've opened up the case and tried pinpointing the location it's coming from but it's hard to tell, I'm thinking either video card or psu? I'll try taking out the PSU tomorrow and see, no time to try tonight. Does anyone else encounter such issue when stress testing? Been prime stable for 2.5 hours now and still going, but it's driving me insane. I currently have my system clocked to these settings:
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 8
- Target CPU Clock: 3000 MHz
CPU Clock: 375 MHz
Boot Up Clock: Auto
DRAM Speed: 333/667 (1:1)
- Target DRAM Speed: DDR2 751
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control: 1.306V
CPU VID Special Add: Auto
DRAM Voltage Control: 1.904V
SB 1.05V Voltage: 1.070V
SB Core/CPU PLL Voltage: 1.55V
NB Core Voltage: 1.37V
CPU VTT Voltage: 1.25V
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Enabled
x CPU GTL1/3 REF Volt: 93
x CPU GTL 0/2 REF Volt: 93
x North Bridge GTL REF Volt: 95
DRAM Timing
- Enhance Data transmitting: Fast
- Enhance Addressing: Fast
- T2 Dispatch: Disabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: More Aggressive
- DIMM 1 CLK fine delay: Current (increasing delay by 1 or 2 & decrease Command/Control delay by 1 or 2 may help 1T/2T oc'ing)
- DIMM 2 CLK fine delay: Current
- Ch 1 Command fine delay: Current
- Ch 1 Control fine delay: Curent
Ch2 Clock Crossing Setting: More Aggressive
- DIMM 3 CLK fine delay: Current (increasing delay by 1 or 2 & decrease Command/Control delay by 1 or 2 may help 1T/2T oc'ing)
- DIMM 4 CLK fine delay: Current
- Ch 2 Command fine delay: Current
- Ch 2 Control fine delay: Curent
Ch1Ch2 CommonClock Setting: More Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL): 4
RAS# to CAS# Delay (tRCD): 4
RAS# Precharge (tRP): 4
Precharge Delay (tRAS): 12
All Precharge to Act: 4
REF to ACT Delay (tRFC): 50
Performance LVL (Read Delay) (tRD): 7
Read delay phase adjust: Enter
- Channel 1 Phase 0 Pull-In: Auto (each Phase when enabled = (Common tRD - 1)
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): 11
Rank Write to Read (tWTR): 10
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): 3
ALL PRE to Refresh: 4
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Any help or suggestions would be greatly appreciated, this sound is driving me crazy :x
