My 9 x 450 @ 4050 bios settings are almost the same as Alien Greys:
Ai Overclock Tuner [Manual]
CPU Ratio Setting [9.0]
FSB Strap to North Bridge [Auto]
FSB Frequency [450MHz]
PCIE Frequency [100MHz]
DRAM Frequency [1199MHz]
DRAM Command Rate [2N]
DRAM CLK Skew on Channel A [Normal]
DRAM CLK Skew on Channel B [Normal]
DRAM TimingControl [Manual]
Refresh Period [16120T]
DRAM Static Read Control [Disabled]
Ai Clock Twister [Lighter]
Ai Transaction Booster [Manual]
Common Performance Level [06]
Pull-In of CH A/B all disabled
CPU Voltage [1.30000V]
CPU PLL Voltage [1.50V]
North Bridge Voltage [1.33V]
DRAM Voltage [2.00V]
FSB Termination Voltage [1.20V]
South Bridge Voltage [1.05V]
SB 1.5V Voltage [1.50V]
Loadline Calibration [Disabled]
CPU GTL Voltage Reference [0.62X]
NB GTL Voltage Reference [0.67X]
DRAM Controller Voltage REF [Auto]
DRAM Channel A/B Voltage REF [Auto]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Delay 200ps]
NB Clock Skew [Delay 100ps]
Ill edit this post and add my 24/7 4320 bios settings also...
My 9 x 480 @ 4320 bios settings are:
FSB Frequency [480MHz]
DRAM Frequency [1204MHz]
Common Performance Level [07]
CPU Voltage [1.44375V]
North Bridge Voltage [1.53V]
FSB Termination Voltage [1.40V]
I have change ACT from moderate to lighter for better stability and if ASUS would ever give us some extra ODT bios settings we could use lower volts (cooler system) or i could run my 8gb gskills with having stability problems as i now have...
