oh ok .. ya i use LLC
that board looks like sex..i want one.
hey lads ive been following the guide here and ive just finished testing my CPU GTLS and everything went fine with the testing and all.
but now when i restart my system it wont post it will just hang, i force switch it off switch on again and post will give me this error
"CPU TO CORE BUS RATIO OR VID CONFIG HAS FAILED"
so i go back into the bios change nothing then posts and gets into windows fine, but when i restart or shut down same thing?!?!??!?!
ive changed the VCC but makes no difference
any help please?
oh i changed the fsb strap from 333 to auto and worked fine.
any ideas??? should i leave it on auto?while i continue oc'ing
The 333 Strap is buggy, notice how it reads 1mhz over for Memory you set to 1:1 with the FSB !
I ain't sure if it really is 1mhz out or just a bad reading.
For me 333 is more stable than 400 which is weird as 333 is tighter.
Pulling all Memory and powering up was way to reset on a NF2, CPU removal is a bit of a choir.
thing was i was testing all the gtls on 333 then all of a sudden said that. changed to auto and not had an error since but not finished overclocking with that guide yet tho
so just wondering shall i ignore the 333 strap error and carry on overcloking or take the memory out and in then see what happenes?
hey lads i tested all the gtls and the longest i got on prime without a crash was 1.19. im going to use that as my gtl is that ok??
in the guide it says you would want one that lasts like 5 mins but that was my longest.
oh and i left my fsb strap on auto, took the memory out and still crashed on 333.
the result i got for 1.19 was on ddr2-872mhz i want to change that and test again on 978 or something around that. it will be faster on the latter right?
this board is quite a big challenge lol
Guys. Can you share with your BIOS settings for Dual Cores oc`ed 500x9 ?
These always seem to work great for me
http://www.xtremesystems.org/Forums/...16#post3469516
A bit too much to read. Simple question - is it a good board?
DonNiger
Yes, this board is great. But why not to go with i5/i7?
Hey guys i want to know what is the best bios for ocing a e8XXX.
Because i am with the same bios from almost 2 years.
I want to lower my vcore a little more because now it is 1.24 for 4.1 ghz i want a little lower.
this is where i am at the mo
my fsb is 513 x8
CPU VCORE-1.26( 1.24 real)
PLL V-1.57950
FSB TERMINATION/VTT- 1.33200
DRAM V- 2.19
NBCORE - 1.29
SB CORE 1.5 - 1.55000
SB 1.1 CORE - 1.15000
Absolutely no difrene when changing bios.
Today i tried to oc my cpu to 4.8 but it doesent want i keep increasing voltages but it boots up windows and blue screen.
vcore 1.53
north bridge 1.42
cpu pll 1.60
vtt.137
and it didnt want to do anything diffreremt when i keep raising
on 4.7 it boots and goes trough benchamks without problems on 1.48 vcore
hello people
I buy this mobo , it is great , my q9550 works with 4,1 ghz /1,336V (vid 1,2875V) , that all , I can not get fsb 495mhz , but I'm happy , for me this is enough , sorry for my bad English , kind regards from Poland
Hi ajdaho welcome to XS.
Nice overclock, you've done better than quite a few people in terms of maximum stable FSB with a quad on this board.
may be this will be helpful for others :
http://images8.fotosik.pl/191/76e802e62b93fa60m.jpg
http://images8.fotosik.pl/191/a428591e50ed7221m.jpg
http://images8.fotosik.pl/191/c6f66335d751e6cem.jpg
http://images8.fotosik.pl/191/ea0d7c13be582b76m.jpg
http://images8.fotosik.pl/191/0e3245f33dbf4d68m.jpg
and my "monster":
http://images8.fotosik.pl/191/9978b0b3aed56001m.jpg
Whatever evga/gigabyte/msi tries to do Asus always stays on top when it comes to mobo's and custom vga's (maybe not msi lightning 260/275)
I'm swapping my X48 board for one of these. Should arrive tomorrow. Looking forward to it!
