Originally Posted by ArmyGreen11
I have the same drives and the same problems. Have you found a fix? On SATA 3/4 I can load the drivers in the XP SP2 install (latest from MSI), format, and copy files over, but as soon as it reboots, I get a windows error screen saying I have a hardware problem (boot path, cabling...) and I'm done. When I'm using SATA 3/4 in the boot path selection in the bios, under the hard drive list, it shows the stripe AND the two drives seperately. If I use SATA 1/2, I only see the stripe, and during install, I get all the way to where it's going to load windows for the first time, and it just reboots after showing the XP screen for a few seconds. I've tried the bios that came with the board, 1.C, and currently 1.Dmod.
I've been thinking about getting a PCI SATA-II RAID controller, but I'm afraid that the PCI bus will be a big bottleneck. Am I wrong in thinking that? I was thinking about either a Promise card, or a HighPoint RocketRAID.
Last night I just forgot about the RAID for now, and installed Vista RC1 on one of the drives (back on SATA 3/4) and had no problems. I couldn't beleive that Vista found ALL the drivers (except my X800SE). Impressive.
