thank you very much for informing me
FELIX
Please add support ATI Radeon Xpress 200
I need datasheets for do that and ATI don't allow access to these infos.
can you add support for vista x64 ?
Vista64 require signed driver for work, and the driver I use with
memset (TVicPort) is unsigned for now; it's the raison that Memset
work on Vista32 and not Vista64.Perhaps at next...
when ? :/ .....
...now: memset
Works under vista x64 !!!!
thank you so much
je te remercie felix
Hey Felix,
Thanks for a great app!
In Vista 32bit, I have to scale DPI to make the text readable on my 32" LCD TV. If I try and launch it with the Vista scaling disabled, I get a
"You must use normal size (96ppp) to use this software," error.
A fix possible?
I dunno if this is a bug or not. & it defiantly makes no diffrence to me.
But on my Laptop which has a 855PM chipset the speed of the ram is constantly changing in memset. It goes right down to about 4mhz when doing nothing on comp & when running mbench I've seen it say 2201mhz & it generally sits between 10 & 100 :s. Ive locked the CPU to 2Ghz & the FSB to 100 using NHC. & CPU-Z dun seems to pick up the speed variation.
Also size is says 512 when i actually have 1526MB of ram so thats odd as well :S
Thank you..
Thanks for the wonderfull program Felix....
Im having problems with memset where sometimes the settings will be all blank except the last 4 values which reads 15-15-15-15.... after that even if I reboot, memset will not function anymore...... anything I can do?
I got the same issue...also on the Commando. ;)
...otherwize you get that:
http://www.xtremesystems.org/forums/...d=11603620 29
and, because memset use differents windows size, make that the soft work with
differents ppp is a hard work with C++-builder (more simple with Visual C++) :
memset is made with C++-builder. :)
->BenArcher: I send you an MP.
->luied & Gautam: Read post #234 on this thread, and don't use the save function if you have this problem, I try to fix that soon...
I think theres a prob in x64 vista version ?:S
I can only run it with compatibility mode for XP or it says ''not for vista 64''
And a second prob is that it reports wrong frequency.
Eg I have 450mhz and it reports 600(sometimes goes up..604-608 and then back to 600 :S)
Can you make it support Abit Fatal1ty F-I90HD?
It uses ATi RX1250 chipset:
http://www2.abit.com.tw/page/no/moth...775&DEFTITLE=Y
->cmos.gr: Try with this version: memset
->BulldogPO: I need datasheet for do that and ATI don't allow access to these infos.
Thanks for the effort on such a sweet proggy Felix. I just picked up a DFI Infinity 965-S and having an issue with running the new version. I get an error that says "the driver TVicPort can not be found". Any ideas?
that's not a fault of the dfi board. you using vista?
No xp. Tried reinstalling program, works once or twice but error keeps returning.
XP 32 or 64 bits?
Is your OS installed on C:\ or D:\?
XP 32bit. C:\ HD location
Hey FELIX, I don't know if it has been mentioned, I am using the old v3.2 and closing via windows (X or taskbar) works good, but when i press the exit button in the app it takes longer to shutdown and when I run memset again the values are missing/wrong, which requires a restart to fix.
Sorry if it has been mentioned before :)
