It must be, none of the L2 can get that high FSB !
L2 are pretty neat ^^
128%?:D
http://users.telenet.be/kuan/4.1.JPG
My 6300 L2 seems ok think it sticks around here
http://valid.x86-secret.com/show_oc.php?id=237348
e2140 Vapochilled. 129%
it's far from orthos stable. that goes around 3600Mhz.
at 459fsb it drops complete dead. no matter what voltage i feed it.
pretty good for a $75 cpu.
Ε4300 @ h2o 3682Mhz ~ 106 % http://valid.x86-secret.com/show_oc.php?id=236445
alltho i need new PSU and coolers on my striker extream heat problems :(
Hello, I´m the new in the club :D
Neuer AMD Athlon64 3000+ Venice World Record !!!!!!
3657,87 MHz @ 9x406,43 @ 1,872 Volt
Sorry, cpulloverclock :D
First 100% OC, Celeron 420 400X9 1,55 V Scythe Infinity Cooled
http://valid.x86-secret.com/show_oc.php?id=232550
SuperPi ran fine, but i couldn't boot higher, and i found no Clockgen or SetFSB that worked ( MSI P35 NEO2-FR, same as P35 platinum) :'(
I got my new Freezer7 heatsink and I cranked 'er up to she what she'll do. I was able to achieve 533FSB x 7 with my E6300 and un-modded P5B vanilla motherboard. I ran the usual tests and temperatures were acceptable and the system was rock solid. I reduced the ram timings to 4-5-4-4-12 with memset, 533MHz is pretty good for DDR2-533 ram @ 2.1v, but I guess it is 533 ram after all :) I tried 535FSB but got blue screen in Windows during testing with the tighter timings. At 540FSB she would boot but flounder.
I know many have higher o/c's and are more stable, ect, but I am pretty happy considering this is a semi-cheapo system with the lowest cost parts throughout. My E6300 is an early one from July '06. It o/c smooth as butter and did 3670MHz with only 1.4v. I cranked the vCore to 1.5 and higher, as temps were not an issue with the new Freezer7 on full tilt. I know this cpu is a golden one and would go much faster with a better mb & cooling.
Asus P5B / E6300 @ 533x7=3730MHz / Crucial 10th Anniv. DDR2-533 @1066MHz @ 2.1v / AC Freezer7 heatsink / Ati X800XL / Seagate 250g/320g / Hec AcePower 420w / SB Audigy SE / CM Elite case /w 2x 120mm fans
http://i32.photobucket.com/albums/d2.../ccpuz.php.png
E2140 (M0 stepping, Q725A)
scythe samurai-z-92mm dc koala
Abit IP35-E
2x512mb Fatbodies
http://valid.x86-secret.com/show_oc.php?id=241522
Celeron 333Mhz s370 @ 724mhz 117%
http://valid.x86-secret.com/show_oc?id=196618
Celeron 366Mhz s370 @ 816mhz 123%
http://valid.x86-secret.com/show_oc?id=196764
Celeron 600Mhz s370 @ 1239mhz 106%
http://valid.x86-secret.com/show_oc?id=197570
E4300 @ 4059mhz 125%
http://valid.x86-secret.com/show_oc?id=217106
E4400 @ 4073mhz 104%
http://valid.x86-secret.com/show_oc.php?id=237629
E2140@ 3496 MHz (AIR Sonic-Tower +2x120) +118%
http://valid.x86-secret.com/show_oc.php?id=242791
Here's my E6600 on a cascade.....
http://valid.x86-secret.com/show_oc.php?id=243004
heres mine.109% i think this is
http://img.techpowerup.org/070920/6300.jpg
asus p5b-deluxe/patriot pc7200@560 5.5.5.15 2.3v
151.51% on LN2 :)
Thread at XS:
http://www.xtremesystems.org/forums/...d.php?t=160590
Pictures:
http://extreme.pcgameshardware.de/sh...newpost&t=2081
CPU-Z verification link:
http://valid.x86-secret.com/show_oc.php?id=248702
wow, awsome result fr3ak :eek:
Core 2 Duo E4500
CPU-Z @ 4543.3Mhz, 106.51%
SPI 1M @ 4440.3Mhz, 101.83%
http://img509.imageshack.us/img509/7...mhzcpuzqy3.jpg
http://img220.imageshack.us/img220/5...13156seln9.jpg
hi guys..i am new user here...
this my system....
http://valid.x86-secret.com/show_oc.php?id=241287 w/stock colling...
ICute 420W PSU...
Congratz to you all, just acquired this baby yesterday and started testing it today, it´s my htpc so for now it´s only stock cooled.
Hope i can achieve more with a diferent cooler and ram, but time for testing is short...
for now 105,6% OC
E2140@3300mhz
1,35vCore
Ddr2 667@800
http://valid.x86-secret.com/show_oc.php?id=254307
:D
Hi there, i just saw this today:
http://s2.simpload.com/th_101447121e1f04485.jpg
is it a bug or am i a lucky person?
Cumps
why would you be lucky if you had one ES?
guys, is there anyway to pick a good stepping for e2140 and e6750s without opening up and benching? at least get some idea, maybe all the L626 or L***As are good chips etc ??
Me E6600 on dry ice:
http://img.photobucket.com/albums/v292/Viss1/17.jpg
Max validated.
Max screen:
http://img.photobucket.com/albums/v2.../5ghzsmall.jpg
E2140 @ 465x8 3720 (132.5%)
Validation
