Ok, I'll try maybe 105 Mhz at the PCIE Frequency, but I can't understand what link it has with the BCLK or QPI? Can you clear me up on that ?
PS : can we rep people on XS forums, cause you are so helpful guys , thanks a lot
cant tell ya why, just known that it works! Def hit up slow mode too as the last resort.
Even with only 1 extra Mhz to the PCIe helped. :shocked:
I'll try how much bclk I can raise with only 1 Mhz PICE, then after the second bottleneck, i'll try to raise again. Thx for your help
Cool man, Im so happy since I discover XtremeSystems...I just need to get use to the Forum...I'll be able to help soon when I finished learning the i7 Architechture on that asus...My Last rig was a Q9650 on a UD3P
Does QPI Link speed affects PC overall performance?
:confused: Just booted up, and saw CPU speeds low, found that while the Bios 602 (or when switched to 0531) show the 21 multiplier selected .. at boot / in windows only a 20 multiplier is active on CPU..
Never happend to me before so can only guess its CPU on the way out?.. as same issue on both Bios..
Anyone seen this before? Should I expect things to get worse, or is there a remedy?
I don't think that your CPU is failing, never heard it fails that way. Could you post your settings using BIOS template?
I can post settings but to be honest, Not sure which you need and when , it does not matter what setting I use .. I still can get 21 multiplier to work..
Everything was working OK,:
21 x 210.4.41ghz. HT off 1.41 v, 1.33 QPI, 1.64, DRAM. Most others default.. had been able to LINX 1hr 4.41 and 4.55 just fine.
So tonight I was Viewing Forum, when BSOD 101 came up out of nowhere.. I little supprised as nothing under stress, then on re boot saw the low CPU speed. :
I will try to pull power... Battery etc.. (in a hope its not CPU)
Post these, if you can, just to check:
Code:CPU Turbo Power Limit []
>CPU Configuration----------------------------
CPU Ratio Setting []
C1E Support []
Hardware Prefetcher []
Adjacent Cache Line Prefetcher []
Intel(R) Virtualiyation Tech []
CPU TM Function []
Execute Disable Bit []
Intel(R) HT Technology []
Active Processor Cores []
A20M []
Intel(R) SpeedStep(TM) Tech []
Intel(R) C-STATE Tech []
C State package limit setting []
These are the current and at the time it happened , tried different combos since.. no change.
CPU Turbo Power Limit [disabled]
CPU Ratio Setting [21]
C1E Support [disabled]
Hardware Prefetcher [enabled]
Adjacent Cache Line Prefetcher [enabled]
Intel(R) Virtualiation Tech [disabled]
CPU TM Function [disabled]
Execute Disable Bit [enabled]
Intel(R) HT Technology [enabled]
Active Processor Cores [All]
A20M [disabled]
Intel(R) SpeedStep(TM) Tech [disabled]
Intel(R) C-STATE Tech [disabled]
C State package limit setting [disabled]
Have you tried Intel(R) SpeedStep(TM) Tech [Enabled] ?
It was needed on my old board to achieve turbo state.
Sorry if I am stealing the thread - dont mean to.
I am in UK and been waiting for over 2 weeks now to get the board.
I have it reserved with OCUK & Novatech. . . they all say eta unknown.
Anyone have any other suggestions as to where I can get the board. . please.
Damn. . I got all the rest of the kit to build this beast and just need the mainboard.
Quick question: Should my mobo function if one of the ramslots seem dead? As of now I can only detect 2 of the sticks, and I have narrowed it down to ramslot A2 by trial and error. I thought I had tightened my Venomous too tight so I redid it, still no 6gb of mem detected.
finally got all the parts for my rig...
Asus Rampage 3 Extreme
W3570
CMGTX2
GTX285 or 4870x2
Antec 1200w
jsut need a few water cooling parts and will put it in a MM H2Go to start.
So it will be easy to work on,
Hoping to lite it up by monday,.....
hope it;s a good board..
new user reporting in :)
waiting for my wc block ......
my country jus too hot to overclock w/o wc ...
can any1 post bios settings for i7 920 at 4.5Ghz pls i can run 4.4Ghz at 1.36v but anything more than that bsod =/
ok all up and running , will report back soon.
before I get stuck in can somone advise of the best Crucial C300 optimizer tool for trim etc, Im a bit of an ssd noob tbh, I have updated the firmware to rev 2. and the drive is the Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s.
thank you
Hey Guys.
I want to reach 4.5 Ghz 24/7 with my i7 930
I'll have 1 HD 5850 overclock to the max
I'll use a BCLK of 215 Mhz with multiplier 21x
I want to know how much voltage should I put in the IOH and ICH, I heard that auto was a bad option
so
IOH Core: 1.31v
IOH PCIE: 1.61v
ICH Core :1.19v (auto is at 1.13v)
ICH PCIE : (auto) I dont have any PCIE x4 cards
Will that be okay?
