Originally Posted by
Ghostleader
Do different chipset have different CPU, NB GTL as default.
Do P45 and X48 have the same
Example:
GTL Ref 0 = ,635
GTL Ref 1 = ,667
GTL Ref 2 = ,635
GTL Ref 3 = ,667
**No not every board either X48 or P45 has the same setup, it depends on how the company wants to configure the BIOS options.
Isīt the CPU who determent what CPU GTL ref thereīs, 45nm, 65nm or isīt the chipset.
**It's a combination of both the CPU and the individual board, for example if you keep the same CPU and replace the board with the exact same board again, you may need to re-adjust the GTL Refs as each set of board components/circuits behave slightly differently and give different resultant voltages even though you have set the BIOS options the same.
What determent the NB GTL ref, does X48 and P45 chipset have the same GTL ref and doesīt change if I run 45nm or 65nm CPU.
**No the default GTL Ref multi of the X48 is different to the P45. What you set it to changes depending on the individual board (what is good for one board may nt be good for another board of the same type) and also if you run a 45nm or 65nm CPU, if you run a quad or a dual core, if you run 2GB or 4GB of ram, and if you run Crossfire or just a single card. It must be tuned for your individual components.
I run a EP45-UD3P board with a E8400@FSB 500 and I found that the most stable CPU ref are ~,635 and NB ref ~,600, the higher FSB the lower NB ref.
With my Q6600@FSB 475 I found that the most stable CPU ref are ~,667 and NB ref ~,700 the higher FSB the higher NB ref.
I have read the whole thread but I still think all this is quite confusing. :shrug:
I understand that thereīs a lot of trail and error also involved in this, I try different settings and Iīm learn new this all the time.
Is there anyone how can answer me questions it will be much apprecieted.
