3dmark06 - 11656
SM 2.0 - 5287
SM 3.0 - 5442
CPU - 2677
8800GTX 575/900 AMD x2 3.5GHz
3dmark06 - 11656
SM 2.0 - 5287
SM 3.0 - 5442
CPU - 2677
http://service.futuremark.com/compare?3dm06=8698000 Well just got my rig running with my new case and it keeping my video cards and cpu running cooler them BAMM! new 3dmark-06 new high score for my self. cpu 3.211 ghz , 4x3850s@ 710/940 , 8.10 ATI drivers.
Os vista 64 bit ultimate
x2 3870's
2.8ghz 1.475 volts
800mhz ram 5-5--5-15.
805mhz both cards 1305mhz mem both cards
3dmark score 14,273
SM 2.0 Score 5407
SM 3.0 Score 7181
CPU Score 3739
My CPU score was 4,300 in XP.
A M$ Windows Update foiled attempt this week :cussing:
My harddrive started thrashing about, reading and writing hundreds of files evertime I booted up, plus network card work would keep disconnecting
Spent the last couple days trying fix it
Did find some stuff I need to improve because this
2 gigs of ram is not enough for Vista, I was wondering why my load times took so long
Ben_Brown got me curious about my power consumption, I got brave and put my power meter on.
Idle was 530W for Trifire
Peak was 803W and that was 3465MHz
If work is slow I hope to replace some the heatpipe cooling crap
It will take a couple of weeks to fix things up
You have a chance to get there first
Good luck
:lsfight:
keep pushing ppl :up:
i need those links to if you have a worthy score
My score:
http://img.photobucket.com/albums/v4...hz_9800GTX.jpg
9850 @ 3Ghz.
9800GTX+ @ stock.
SM2: 5642
SM3: 5981
CPU: 3945
Final: 13566
Will be my scores be noted???
http://service.futuremark.com/compare?3dm06=8741326 Ok here my newest run this move me up the list 17,382 cpu at 3.185 ghz , 4x3850 @725/950 :)
Well, i even yet to clock my card so ya, 14K+ was possible 100% :D
Rerun the test a few run should yield me 4K CPU score haha
Im on vista 32! Song arh! :D
System:
GFX: ATI Radeon HD 3870 X2
CPU: C2Q9450 @ 3084MHz
MEM: 4Gb (only 2672Mb visible :mad:) @ 963MHz
OS: Windows Vista Home Premium 32bits
Results:
3d Mark Score: 16958
SM2.0 Score: 6691
HDR/SM3.0 Score: 8105
CPU Score: 4612
Hey ,, Not try to start stuff ,,THIS iS AMD CPU result thread....But that is a nice comparison...Please post only AMD cpu's ,,
Thanks,,
gOtVolTage
sorry!!!!
didn't noticed.
Ok got out the voodoo dust for my poor litte 3850s http://service.futuremark.com/compare?3dm06=8765729 vista-64, cpu@3.263, 4x3850s 720/950,
ATI 8.10 drivers :shocked:.
Wow those 3850s are impressive :up:
Thank you
For a lower midd range video card the one thing 3850s do very good is run as a team in crossfire . They got just enought pop to get some FPS but they don't over power the cpu so when you team them up in crossfire they can run every good .Once i up grade my cpu and hit the 3.4 to 3.5 ghz range i think the 3850s can go into the 18,000 range out at 3dmark-06 . Hell with a cpu 3.5 they mite hit 19,000 .
That would make me sad if you break 19,000 with 3850's and I can't do it with 3870's.
I have given up on the 3870's though and I am trying to sell them and go with either quad 4850s or 2x 4870x2. Not sure which would be more fun.
For me it about better cpu clock speed at 17576 i realy do think a bump up to 3.4 ghz on the cpu would put it into 18000 .Than there the talk about DX11 the 3850s do DX10.1 and play any game i got good enought for me so i'am waiting to see if we are going to need new video cards for DX11 .
