this is the x48 DK ...
http://us.dfi.com.tw/Upload/Product_...%20X48-T2R.jpg
Anyone knows, if these board supports the Tuniq Tower 120?
Thank's
I'm having an odd problem with my overclock so far. I have an E3110 and anything over 1.26v to the cpu and it refuses to boot. I'm stable at 4 gigs right now at 1.25v and i guess what's weird about it is if i try 1.27v at the same speed, 4 gigs, it doesn't boot. I've went up to 1.35v just to see if that solves the problem and the same thing is happening. I could understand if i've hit the chips limit but being picky about volts is odd.
I have everything in the bios stock other than the cpu and ram volts. I did disable all the chip extra such as vm technology and whatnot.
Any advise?
E3110
G.SKILL 8500 2x2
TRUE
stock NB cooler.
I just got my DFI X48 and 4gig of of OCZ Reaperx and Q9450 from tank guys I am having alot of issues getting this to overclock. Anyone have some setting I can start with ? 3.2 is all I can get so far.. there are so many setting in the bios
what is everyone running for NB volts and CPU VTT
Thanks !
Besides the MIPS block, is anyone aware of a waterblock that is compatible with this board for the MOSFET?
Alternatively, if someone could provide the mounting hole spacing measurement for the MOSFET heatsink it would be a big help as well.
Thanks!
The first pic i ran last night and it was stable when testing just the cpu and the second image is of the blend i did that failed this morning. Another odd thing is when the computer will not boot up after up'n the volts it comes on for about 1-1.5 seconds and then shuts off. I have to clear the CMOS as its not able to restart itself and the hotkeys for bios load don't work. Ugh i'm having problems heh
http://img241.imageshack.us/img241/8...zstableaj4.jpg
http://img122.imageshack.us/img122/8233/4ghzfailmz2.jpg
I haven't tried that but i guess it's worth a shot.
Waiting for the DDR3 version and then letting a month or so pass for BIOS maturity is the hot scoop.
To get maximum overclock,which is the best DFI board to get between these 3?
DFI LP UT P35-T2R
DFI LP LT X38-T2R or
DFI LP LT X48-T2R?
I was asking especially for a QX9650 CPU and 4x1GB Crucial Ballistix DDR1000
Cant tell you hand on heart as I've never had a 45nm quad but I'm sure someone will chip in & help you out.
What I can tell you is all the boards will do 500fsb easy so you wont run out of 45nm quad fsb headroom (the CPU will give up before the board) & all of the boards will clock 4 x 1gb sticks past 1100mhz easy too.
CN :)
Got a pretty good 32M time with an E2160. :) (This E2160 is good up to 3.8GHz with air cooling)
http://img261.imageshack.us/img261/1149/sp32mxf1.jpg
There are only two possibilities:
- MIPS Freezer
- Watercool HeatKiller SW-16
But neither are easy to get a hold on here is US.
So everybody interested in getting the MIPS and split shipping sign in here:
http://www.xtremesystems.org/forums/...d.php?t=182949
If you are referring to upping the vcore volt me and other 2 ppl reported the same issue. Tried different PSU's in stock settings and when volts get near some marging the mobo will not post properly anymore.
Turns ON then shuts off after 1-1.5secs...
Not heat issues so i guess i was awarded with a 2nd DFI RMA :mad:
Could you possibly link the post you're referring to? My cpu vid cutoff is right at 1.3 and i've tried up to 1.45 just for the hell of it with no luck. I have however finally got the INSERT key to reset my CMOS when this happens but it takes 1-3 times of me pushing the power button on/off and holding the key down for it to take. I've reported this issue on the dfi forums as well and i see someone else has the same problem as us. I did notice in his signature that he had an E3110 like me but i could be jumping to conclusions =)
So to sum this up for myself, and a few other people, are these the best recommendation for coolers (air) to use on this board?
CPU - TRUE
NB - Thermalright HR-05 SLI
SB - Enzotech SLF-1
Thanks for the input!
I just noticed something that struck me as odd:
http://img225.imageshack.us/img225/4549/tempsoffxm4.jpg
