Some more picks of my water cooling goodness:
The Keg has two power connectors, and Seth supplies two quality power wires.
I opted to make two connectors into one to cover more distance using some of the wires I already had laying around. I plugged two connectors into the Keg and made a plastic spacer to keep them the exact distance apart, that the Keg liked.
I soldered the wires togeather, then using electrical tape covered each one individually. I also then wrapped the entire rig up in more electrical tape, to keep it all together.
http://img137.imageshack.us/img137/3967/pic076ry1.jpg
I spliced a connecting wire together, with two female ends. These were also soldered together.
It's now plenty long, for the distance that I needed to cover! :up:
Just one wire to connect to the computer now too.
http://img137.imageshack.us/img137/7606/pic077ky2.jpg
One shot of the rear:
http://img137.imageshack.us/img137/2057/pic080va9.jpg
I tried setting the Keg on the desk, but I still favor it on the credanza, off to the right hand side for final placement.
I will make a gradual bend in the tubing, and won't worry about it.
I just want the Keg setting in my favorite spot for it.
I consulted with local member 'Flo-Master Martin' in a few PM's, and he dosen't feel an extra foot or two of tubing, will add any large resistance into my loop.
This will be where she sits, with the computer on the right hand side of the desk:
It is hard to tell, but the Keg has a good foot between it, and the wall.
It should be able to breath there fine.
http://img339.imageshack.us/img339/9404/pic072jm4.jpg
Update:
Making full use of my self sealing fittings, I decided to fire the Keg up, even befor my mobo is togeather. (Us McMASTER-CARR boy's just got it like that.) ;)
I had the 5 micron filter in the loop too, and successfully cooled it for about 5 hours. I made a newbie mistake and didn't order the teflon tape to put between the fittings, and the filter. It had a slow leak, but just setting the trash can filter on a paper towel, was good enouigh to absorbe the slow drip.
SELF NOTE: Must buy teflon tape to make the filter seal against the fittings.
My rad, pump, and lines are getting burped at the time of this posts editing. :up:
Both lights work, and no leaks of any kind inside the Keg. The unit works as advertised.
490 Wats of cooling power for my Maximus SE is now online!!
I was running straight distilled water when my 5 micron filter was in the loop. I removed the filter and put some water additives in.
My loop is currently using 1/2 a gallon of distilled water (64 FL oz).
I mixed in with that 2 drops of PT Nuke, and 1 full 4oz bottle of G11 UV Blue:
http://img525.imageshack.us/img525/213/pic083vj7.jpg
One shot in the dark: Note - These are not UV lights, the G11 won't react until it enters the TJ09.
http://img525.imageshack.us/img525/5447/pic085ul6.jpg
