6.6.15 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
OS X command line version
Edit:
Linux 32 bit
Linux 64 bit
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
6.6.16 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
6.6.17 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
Lots of post missing...
6.6.24 beta is available for:
Windows 32 bit
Windows 64 bit
6.6.23 beta is available for:
OS X
6.6.20 beta is available for:
Linux 32 bit
Linux 64 bit
6.6.25 beta is available for:
Windows 32 bit
Windows 64 bit
Thanks for keeping track of this for us Sunfire. :up: :toast:
Regards,
Bob
Ooops, I almost forgot:
6.6.26 beta is available for:
Windows 32 bit
Windows 64 bit
:D
Too bad I can't try it out, my rig is far away from me now.
Edit:
OS X
6.6.27 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
Even for betas they are releasing too fast ... not enough internal systems testing going on as there is already 6.6.28 because 6.6.27 broke cuda entirely! I have been running 6.6.20 and it is OK because I only crunch WCG and GPUGrid but the scheduler is screwed up if you run mulitple projects. Really, take a look at the release log ... how many versions in the last week alone???
I don't know, but here is another one:
6.6.28 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
6.6.29 beta is available for:
OS X
6.6.28 for Windows and 6.6.29 for OS X are recommended!
Linux 32 bit
Linux 64 bit
6.6.31 is available for:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
Edit:These are recommended versions!
6.6.33 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
Linux 32 bit
Linux 64 bit
6.6.34 beta is available for:
Windows 32 bit
Windows 64 bit
avoid this version if you're also CUDA gpu crunching...
http://www.gpugrid.net/forum_thread.php?id=1128
WARNING: Due to a big bug in this version, do not upgrade to it when you're using any sort of CUDA device and are using it to crunch. Your work will get lost.
I just read Boinc version 6.4.5 is not recommended. Did not specify OS. My Linux 64 quad is running 6.4.5 and so far seems fine. Anyone know what the problems were and if it was Windows specific?
Yeah I looked thru this thread and seemed like it worked fine for several and no one complaining.
thanks
:toast:
Guys, which version is best for x64 if I am also folding (CUDA) ?
I'm still on 6.6.28 on 4 cards, but 6.6.31 is the current one http://boinc.berkeley.edu/download_all.php
I just haven't upgraded to it yet. thats the one I would use
New BOINC clients arrived:
6.6.36 recommended version for:
Windows 32 bit
Windows 64 bit
And 6.6.36 beta for:
OS X
Linux 32 bit
Linux 64 bit
I am using version 6.6.31 x64 in Windows 7 Build 7201. I am having an issue when the screen saver comes on and the display turns off. It takes a while (10 ~ 60 seconds) to regain control of the desktop (one BSOD). I have checked the 'Compatability Tab' for Vista SP2, and that seemed to improve the response time. Are there plans to upgrade the software anytime soon? I have narrowed the problem down to this program when it is running.
Turn off the screen saver? The screen saver is a resource hog anyways.
I run in Win7 with absolutely zero problems.
