I got the SL9ZL stepping on my E6600, How good is that?
currently 3.4 55c load on my freezer7
L629F221
P5k-dlx rocks this chip very easily.
Mid Orthos -
http://img72.imageshack.us/img72/372...thosqc8.th.gif
Post Orthos -
http://img293.imageshack.us/img293/7...idleam6.th.gif
3dMark05 -
http://img297.imageshack.us/img297/2...rk05iz5.th.gif
Mr Cape.
You night want to think about water cooling. Those temps under load are kinda high. I bet under water that chip has alot more in it. :up:
Motherboard: EVGA T1
CPU: E6600 L646G494 @ 3.7Ghz. 1:1 Ratio Linked & Synced Voltage 1.44 Load temps 45c
SPP:1.45volts, MCP: 1.50volts
Memory: Mushkin PC2 8000 4-5-4-11, 2T Voltage 2.1
Swiftech Water Cooling H20-220
Video: One EVGA 8800GTS 320MB
Power Supply: Silverstone 750W
OS: XP Pro
57c is not high for c2d in load. 60+c and thats starting get pretty high.
Yeah Orthos cranks the temps but that's nothing really. I never hit more than 61c in Orthos. My gaming load in Oblivion with highest settings/antiailiasing is 42c in RMClock. Core temp 40c.
There's a lot of differing opinions about what temps these conroes can handle but I'd cut it off if it got over say 64c. That's my assumed safe limit.
Yeah I noticed that too, there's a pretty steep rise in temps once you go over 1.32v or so. I guess it's part of the deal to get that last couple hundred mhz.
I can say that I'm very happy I bought this one instead of a random newer batch. Then again those GO chips are looking awesome now too. Haha, time marches on...
One more screen @ 3.7...
http://img527.imageshack.us/img527/2...idleoi9.th.gif
Alright, last one for today but I still want to go more -
3.8ghz -
CPUZ Validation
http://img412.imageshack.us/img412/4...idleir5.th.gif
I did some browsing and did the screen cap in photoshop. It seemed fine, so fast, but I didn't want to try orthos.
Dropped back to 3.6 to do some work. Man running this speed really makes you realize when you make a user error, there's no pause. Just mouse clicking and tabbing around is so instantaneous like woah, where did that app go.
[QUOTE=mrcape;2252962]Alright, last one for today but I still want to go more -
3.8ghz -
mrcape, I totaly forgot you had one of the F chips. Yes they do get warm mighty fast. Congrats on the 3.8Ghz on air. Amazing!!! :woot: I will be trying 3.8Ghz today hopefully. Will let you all know how it goes.
CPU: E6600 L646G494 @ 3.7Ghz. 1:1 Ratio Linked & Synced Voltage 1.44 Load Temp 45c
Idle Temp. 25c
OS: XP Pro
My L706A499 is @ 3.7 1.42 VCore. I am working on stability with my ram now to try get higher clocks.
You are using the badaxe while he is using a P35 board, so far there seems to be a big difference in the abilities of the P35 when it comes to OCing the E6600s in that it typically takes lower vcore to achieve the same OC. Though Spi times indicate the P35 not to be significantly (if any) faster than say a P965 it does seem to allow for lower voltages.
Today i got my new L709A964. It´s an funny one. I can boot with 3.6ghz and 1,3v but it isn´t primestable at 1,48v. Maybe it´s benchstable but first i want to get it primestable. Always if i start prime core 0 runs fine but core 1 makes trouble. But the temperature ist much better than the temperature of my L629B.
My 744G can even boot into windows at 3.8 at 1.45, but I can't get the damn thing to run at 3.6Ghz not even at 1.55 real vcore, temps go way up to 65°C now, so I lapped the CPU, to see if I can nibble some degrees off... I settled before at 3.4 due to temps...
At the moment running Intel TAT at 3200mhz at 1.35 Vcore both cores read 40°-43°C out under my thermalright Ultra 120. Will have to let the AS5 settle , then try more Vcore again and hopefully the lap job did something...
I have a very late E6600
L789A269 :O
Cooling:
http://i6.photobucket.com/albums/y21...th2/Ghetto.jpg
Swiftech Storm G4 CPU block
Swiftech MCP655 1200lph pump
BIX Stealth 240 with 2x 120mm 100cfm panaflo's
1/2" clearflex
23C ambient most of the time
GeaR:
E6600 L789A269
Gigabyte 965p DQ6
Radeon HD2900XT
Audigy2 ZS sound
Silverstone Zeus 650w
I acheived 3350MHz when I was on stock cooler, stock vcore (was 1.344 loaded) 8 hours orthos stable with 54C loading temp
On the water:
3712Mhz 1.54v loading (1.6 BIOS set)
http://i6.photobucket.com/albums/y21...3700-prime.jpg
http://i6.photobucket.com/albums/y21...h2/pi-4050.jpg
Fails after a few seconds in orthos at anything over 3.89 with 1.6v under load.
+.20 on Mch
+.20 on FSB
F9 BIOS
Cheers
L639F027
It needed a lot more V to get benchable at this speed, but with H20 and a bit more juice I think this could be a 3.8 benchable one ;)
3580MHz
399*9
1.55V
Ram just stock 2.2V
GFX stock.
PI 1M is the newest there.
http://kirkedam.mine.nu/kwk/Data/Ove...ofarsogood.JPG
L645G337
Chip is definately a volt hog
3.42 (380 x 9) @ 1.53v bios, 1.50v droop full load
VID=1.35v
ran 24hrs stable Orthos blend
runs Small FFT's at 55 C. with lapped tuniq and ihs.
idles @ 30/32 C.
Ok, I have 3.9GHz Benchmark stable, yet to prime it.
I have 3.8GHz prime stable with 1.57 REAL vcore under load. (same V as used to run 3.9GHz benchmarks)
I bought a 630F from Tank Guys, I just got it going today and it passed OCCT @ 3816 1.55 vcore. I have not got a chance to do much with it but it will run SuperPi @ 4Ghz and boot into windows but it take 1.65vcore
I never tried the Vcore higher then 1.55 on the 630F because on that rig I'm on air and temps were way up even though the Vid was lower ... so I sold it, I played with the 744G, also heating up like a madman over 3400mhz, so I lapped it and now it's 3600Mhz stable at 1.49 Bios setting which corresponds to 1.48 real volts on my P5K under load...
Gonna lap my 632A too and see i I can gain some degrees there...might hit the 4ghz barrier with some incredible luck....
Kallenator I have the same E6600 as you (L639F027). Unfortunately that CPU requires a lot of voltage :( I can't even boot it with 400x9 and now I'm working to have it stable at 355x9 :( Do you have any tips for that CPU?
Gaming Rig stable at 4G. Able to boot and play at 4.32G (9x480) but not Orthos Stable.
Stability: 11 hours+ Orthos Blend stable
CPU name: E6600
OC: 4050MHz
Stepping: 6 B2
Week: L709
Code: A442
Vcore: 1.65V (Bios) 1.58v (vdroop)
Cooling: Vapor Phase
Cooler brand/model: Vapochill LS
Motherboard: EVGA nForce680i SLI A1
Bios Version: P28
Operating System: XP 32
RAM brand: Corsair TWIN2X-6400C4
RAM rated speed: PC6400
RAM actual speed: 800
Latency: 4-4-4-12-2T
Vddrs= 2.1v
Are there any good 6600s still on the market? The ones with 1.23v base setting or just low temps?
