Right now, it is running on my board. I thought it would have been hosted by now. ;)Quote:
whoopsQuote:
Originally Posted by bingo13
share it.... :toast:Quote:
I have the F3 release.
Any New beta BIOS for the DQ6?
Mel
yeah share it!! :D and maybe a list of changes?Quote:
Originally Posted by soki
what happened to the new bios?
If you guys want I can host the bios files on my rapidshare account....Quote:
Originally Posted by Pyr0
I'm looking for a bios that I can change memory timings with. I just DL the F4 from Gigabytes website but I still cannot change memory timings....
nm :(
Yes Please do so.Quote:
Originally Posted by RangerXLT8
ranger....... if you would hit Ctrl-F1 when your in the bios you can change anything you want you have to do it on the main page of the bios
please dont tell us you didnt know that.....
Anything new on the DQ6 front?
where is it?! :slap:Quote:
S3 F3 BIOS:
http://rapidshare.de/files/29449308/965ps3.f3.html
DS3 F4 BIOS:
http://rapidshare.de/files/29449591/965pds3.f4.html
DS4 F3 BIOS:
http://rapidshare.de/files/29449772/965pds4.f3.html
DQ6 F3 BIOS:
http://rapidshare.de/files/29449947/965pdq6.f3.html
PLEASE VERIFY BEFORE USING.
is that the same DS3 F4 BIOS as the official one from the gigabyte site?
yes they areQuote:
hehe u guys have the same name
i should have my board thursday(sigh so close) so the F4 off of gb site is best for now, DS3 is the board
f4f > f4 ? for ds3
just got mine E6400 week 26, and gigabyte DS3 with a value mushkin ddr2 800. I'm going to put my force chipset cooler on the nb.. Hopefully can oc to 3.2GHz.
F4 for the DS3 made my CPU temp go up 6 degrees and my system temp droped 2 degrees.
i think my DS3 died :(
i changed some settings in Bios and now wont Boot , the computer is turning OFF and Turning ON automaticly in a cicle and only turn OFF if i turn OFF directly in the power suply .
I already tried clear cmos but wont boot , its the same thing ( turn OFF , turn ON , Turn OFF , Turn ON ......) .
any tips before RMA???
sory for my english
regards
Desliga a board, retira a pilha e faz clear cmos. Espera 1 hora e volta a por a pilha.
oooohhhh week 26 E6400. I wonder how that overclocks compared to the week 25. Please let us know of your oc resultsQuote:
Originally Posted by irenic
pois ja fiz isso tudo , isto aconteceu-me a 15 dias no dia em k fui d eferias , xeguei ontem e esta na mesma , vai ter mesmo k ir pa RMA :(Quote:
Originally Posted by MonkSP
cumps
Are you sure that you have a good clear CMOS ? ATX powercable out of the motherboard, take of the bios battery and hold a metal piece between the jumper pins of the clear jumper.Quote:
Originally Posted by mascaras
I have the same problem yesterdag. A Simple Clear cmos fixed it.
yep, powercable out, battery off and use the DVD-RW jumper in clear cmos pins and its the same ( on-off-on-off) :(Quote:
Originally Posted by The_Hardstylez
regards
