Did you reinstall Windows?Quote:
Originally Posted by flenser
What BIOS you curently running?
MoBo MSI K8N Diamond Plus
FSB clock in BIOS limited to 320MHz, in manual 450.
Where disappeared 130 MHz ?
CPU x2-3800+ e4.
Wich program do you guys use to mod a bios from the MSI K8N NEO 2? I need this because I cant select the advanced timings for my memory! :mad: I saw bios release for tccd ram and other ram but they dont fit for my memory.
BIOS from AWARD, right ? If yes, then modbin6_1.00.38.
http://tinc.narod.ru/bios/modbin6_1.00.38.zip
It work correctly only under DOS.
A quick question, What kind of amps/watts/current can a fan header handle on the motherboard?
I went through my manual, the web site and did not find the answer. I was told on another forum to expect 0.5A max.
Thanks man! It works finnaly :toast:Quote:
Originally Posted by TINC
where are the pictures of the vcore mod(s) for this motherboard? as i remember they were up here and now i have finally gotten around to doing the mod(s) and they are not here
I have tried uccc but for some reason my msi did not like them, and with kigston it was even worse. So for 2X1gb i would suggest a pair of supertalents. With 2.8 they easily did 240 3-3-3 with the rest of the timings quite tight. They like the extra voltage so i am waiting for summer to go by so that i can mod my 3.3 and up the vmem to 3 and see what happens.Quote:
Originally Posted by TiTaNiUm
144 here also @2950@1.55
I cant get mine to post using the 10x multi when i try 10x280 with out first booting @ 10x160 any ideas on Y ?
What has happened to Sideeffect and all his great work? Wasn't there a 1.C3 Final Modded BIOS made?
Ok now the sites working. Thanks
Was it down for some reason?
Anyone had a problem with this motherboards GigaLAN not working? I've tried everything I can think of. I even reformatted XP. The network device shows that it's working, but it's not receiving any data.
i did, one of them wont work for me, it has 2, one works and one doesnt, but it will work for a LAN connection.
use the realtek one, it works with DHCP
Originally Posted by MaRtIe
Yeah the bottom one (realtek) works I was just thinking that maybe I did something wrong.
links to vmods for thsi board ?
There was some but I think the sites are shutting down.
http://www.ocforums.com/showthread.php?t=339051
Going to try this:
Component:
Integrated nVidia LAN
Links: Problems with LAN
K8n Neo .. lan died
Problem pops up:
Suddenly.
Problem description:
The nVidia NIC is working just well, then, suddenly, there is no LAN traffic, the network link exists but you get no responses to pings and there is no internet, you don't have a IP. There are no enumerated LAN devices.
Possible cause:
The O.S(XP) turned OFF the NIC interface to save power.
Possible work around:
Remove the motherboard stand by power. Shut down O.S.. and remove AC from PSU by two/three minutes.
After this, disable the save power option in NIC device configuration for this device.
Thanks to Syar for Solution
:brick: didn't work
Hey sideeffect,Quote:
Originally Posted by sideeffect
Thanks for links. I wanted to know if you knew anything about the my new RAM and the advanced timing settings for it. It's Corsair Twin2048-3500LLPRO that uses Infneon -5 64M X 8 Rev B chips. I have trouble getting it to overclock as I see everyone else doing. Would you be able to make a BIOS that has more of the memory timing options?
Read/Write Queue Bypass
Idle Cycle Limit
DQS Skew Control
And any others that you can.
Do you have any info on how to use the BIOS editing software you posted on you site?
Thanks for you time.
Shawn
hi guys, i have a question: in order to make to work ddr booster the servants who the local power supply distributes the tension of the -5V? i have the hiper 580W.....
sorry for my bad english i'm italian
You only neeed -5V (usually white cable in ATX plug) to actually see the V value on a display.Quote:
Originally Posted by stalker170
The Booster WORKS without -5V but you cannot see how much volts it's feeding. However, if you use a multimeter to measure it you can live without -5V rail.
ShawnTRD
Can you post some benchmark scores with your system..Thx
yupQuote:
Originally Posted by Losphoron
