i just did my rebuild
http://i51.tinypic.com/1z3nxp4.jpg
i know that the psu is a mess but its running great (the rez is also empty but the t-line is not, it was for filling only and worked out perfect to be right below it when its running.
ahh you mean something similar to this? Project SASHA
Some hardware upgare on my HTPC.
I thought that maybe you are interested in. :)
http://img854.imageshack.us/img854/6880/72915334.jpg
http://img130.imageshack.us/img130/5492/54963089.jpg
http://img651.imageshack.us/img651/7397/83283029.jpg
http://img718.imageshack.us/img718/2679/58484746.jpg
Config:
PSU: Corsair CMPSU-750AX Modular
MB: Asus P8P67 LE Sandybridge
CPU: Intel Core i7-2600K 3.4GHz @4.1GHz
VGA: GIGABYTE ATI-AMD HD6970 GV-R697D5-2GD-B 2GB GDDR5 PCIE
RAM: Apacer 4096MB 2000MHz CL9 DDR3 ARES KIT
SSD: OCZ RevoDrive PCI-Express SSD 50GB
HDD: (old) 2x Samsung 500Gb Raid0
SOUND: ASUS Xonar D2X PCIE
Blu-ray drive: Pioneer BDR-205
CASE: Thermaltake DH104 HTPC case
Main water components:
PUMP: Laing D5 Solar
CPU: Koolance cpu-340 with socket 1155 mounting
VGA: EK Water Blocks EK-FC6970 full cover
SB: Watercool HEATKILLER® NSB Rev3.0 LT
HDD: Watercool Silentstar Dual Box
Tubing:Tygon 3603 19/13
Rad: Watercool MORA2 PRO
Reservoir: Koolance 120mm
FANs: 2x Scythe Gentle Typhoon 120 mm for CASE (blowing inwards on reduced RPM)
and Scythe S-FLEX SFF21D (800rpm/8.7dBA) for the PSU (reserve airflow blowing inwards).
and more images... :)
http://img101.imageshack.us/img101/2885/36653687.jpg
http://img692.imageshack.us/img692/5452/47738536.jpg
http://img585.imageshack.us/img585/4043/17838897.jpg
http://img690.imageshack.us/img690/5760/83127186.jpg
edit (by Shazza) - nice, Logaan, but please note there is a 4 image limit per finished system (image links changed to url - correct me if this is actually a different setup than the one you just posted)
That is NICE Logaan!
I use PrimoChill PrimoFlex PRO LRT 1/2" ID - 3/4" OD tubing. All you gotta do is attach it to one fitting and then twist the tube in the direction you want it to twist and it will do it and maintain it. Just make sure you dont over twist it or you will constrict the flow if the tubing becomes thin at the twist.
Thanks guys, I am really happy with the outcome and the twists and curves are what catch people's attention the most.
I dont intend on drinking those beers or liquors, they are about 10 years old, from my first legal purchased batches hehe ;)
I love them too, specially when playing games, those puppies go NUTS and flicker all over the place!
@ Hugo, I dont intend on drinking those beers or liquors, they are about 10 years old, from my first legal purchased batches hehe ;)
Forget the beer, the liquor gets better with age!
Once again, excellent build!!!
I just completed my SandyBridge rig. Enjoy:)
System Specs:
Intel i7 2600k
Asus Maximus IV Extreme
G.Skill RipjawsX F3-17000CL8D-4GBXMD +Turbulence II Fan
MSI N560GTX Ti Twin Frozr (Waiting for Waterblock)
64GB Sandforce SSD in RAID0
Samsung BluRay Burner
Corsair AX1200
Corsair 800D
Watercooling Specs:
Swiftech ApogeeXT
Swiftech MicroRes
Ek Coolstream 360 Rad (w/Scythe Gentle Typhoon)
Swiftech MCP655 w/speed control (Fully modded BP Housing,BP Mod Top V2, Sleeved)
BP 7/16" x 5/8" Compression Fittings (Matte Black)
PrimoChill Pro LRT White 7/16"x5/8" Tubing
White Sleeved 8Pin, 24Pin, and 2x6Pin PCIX
I wanted to show off the pump so I put it in the main compartment of the case instead of down next to the PSU. After getting it all put together I am not 100% sold on the placement so when I get the waterblock for my 560 Ti and possibly a second 560 Ti for SLI I will probably put the pump in the bottom PSU compartment.
Any suggestions or thoughts?
@deachus Nice build all around and very clean too!
nice looking build deachus, now throw that gpu under water too :D
Every time I come in this thread I cry a little more about my build... :(
Grommets 16-10 with 13mm tube, do not need clamps :-)
http://noaimc.vs120092.hl-users.com/plan8.jpg
Here is my first liquid cooling attempt!
http://img.photobucket.com/albums/v3.../croppedWC.jpg
Been running for 3 days.... Few more clamps need to make it look pretty! More Koolance fittings coming
My current setup. The first picture shows what was before :)
Thanks to my little son for helping his dad with this :)
ASUS Maximus II Formula
Core 2 Quad Q9450
8 GB Kingston DDR2-800 C5
Palit GTX 285
OCZ Vertex 2 120 GB x 2
Corsair AX850
Lian Li PC-P80
Thermochill PA140.3
Swiftech MCP655 Vario + EK D5 Top V2
EK Supreme HF
EK GTX285 GW
EK-250 Advanced reservoir
Feser One F1 UV Red + Tygon 13/10 mm
Bitspower fittings
